Old 09-17-2019, 05:45 AM
SteveR SteveR is offline
Default Need opinions - insulation wrap in engine bay
I'd like to get thoughts on the pictures below. This is 2,000 degree insulation wrapped around exhaust and an oil cooler tube. My concern is that this will be a fire hazard as the insulation gets coated in oil over time.
Old 09-17-2019, 08:31 AM
kaweeka kaweeka is offline
This is from Vetterman's website. It may not directly answer your question but it's worth considering if you are unsure about the wrap. I don't know what your exhaust is constructed from and I am definitely NOT an engineer but take the advice from trusted sources seriously.
"Any material on the exhaust will shorten it's life and failure will occur. We are using air cooled engines and one the best heat sinks on the engine is the exhaust system. The mass air flow comes in and is forced down and around the cooling fins and then is directed over the exhaust system and then exited out the bottom. If the exhaust is covered it cannot aid in the cooling process. Our tests show that any type of wrap on the exhaust makes both the cylinder head and exhaust temperature run higher. The stainless steel used (type 321) will degrade if the surface temperature is over 1250 degrees F. We also did not find a power increase of any kind by wrapping the exhaust"
Regards,
David
RV-9A N435KR, Vans calendar March 2018
LIO 320 B1A, Dual LS Plasma III, AFP injection
G3x touch
Roseville, Ca
Old 09-20-2019, 06:59 AM
Red Mtn flyer Red Mtn flyer is offline
Default concur
worst placement of 'insulation' is around the exhaust -- it will shorten life [constant temperature swings means precipitation of moisture, retention of heat, etc.], makes visual inspection essentially impossible... a pinhole through the pipe into the wrap and what do you have??? - a mess, if you're lucky.
Vetterman's thoughts are 'right on' -- use the airflow to cool.
Ben K.
A&P; RLSA - A,G,W/S Falco F-8L
50 yrs of flight and counting
Dues paid 2017 thru 2020
Old 09-20-2019, 07:16 AM
terrykohler terrykohler is offline
Default Are Those Plastic Zip Ties????
Wrapped around an exhaust pipe? If so, I'd have a verrrrry careful inspection done of the entire aircraft. They're likely to be other surprises.
Terry, CFI
RV9A N323TP
Old 09-20-2019, 08:06 AM
DennisRhodes DennisRhodes is offline
A lot of LongEZ flyers used wrap around the exhaust pipe to "help" with the CHT since the cooling in most EZs is updraft. The results WERE a shortened life on the stainless or other exhaust material, mine included. In an EZ anything that broke and got out of the cowl went thru the prop!! Wrap for that service presented a whole new level of inspection in that aircraft. The good news was that a cracked exhaust usually stayed in the cowl held by the wrap and wire until inspection revealed the exhaust leak . Exhaust Wrap not a good idea.
DRRhodes
2020 VAF Supporter
RV9 N908DR
Old 09-20-2019, 08:07 AM
airguy's Avatar
airguy airguy is offline
Aside from the points already made about this being a very bad idea, I have to laugh a bit at the PLASTIC tie-wraps used on the exhaust insulation...
Old 09-20-2019, 11:43 AM
DanH's Avatar
DanH DanH is offline
Plenty of RV-relevant content here.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-20-2019, 11:55 AM
Default Agree
Agree with the RV content...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 09-20-2019, 01:26 PM
...seems quite relevant to me.
G3x touch
Roseville, Ca
Old 09-20-2019, 08:20 PM
gasman gasman is offline
Good to go then................
VAF #897 Warren Moretti
2019 =VAF= Dues PAID
