Old 09-15-2019, 02:14 PM
Maxrate Maxrate is offline
Default Thank God for torque seal
After helping a friend complete his condition inspection to include replacement of all fluid lines and overhauling the fuel injection system I discovered the throttle cable to fuel injection control arm nut loose. The only thing that raised my awareness was the lack of torque seal applied! We double checked every nut and bolt FWF after finding that little revelation. I think the additional step of adding a swipe of torque seal after final tightening quite possibly saved our bacon. Maybe the AP would have discovered on his final inspection, and maybe not! When multiple guys are working on a project, having a procedure in place of torque sealing after final torquing is vital, imho.
Mark Malone, RV7
Wings complete, SB 14 complied with, canopy and cowling in progress, Up on the gear.
N442MM reserved
http://www.mykitlog.com/MikeMike
2020 Donation gladly paid..
Old 09-15-2019, 02:44 PM
DanH's Avatar
DanH DanH is offline
You mean like "Physically check all the nuts and bolts"?
Seriously, torque seal only proves somebody put torque seal on it. A wrench proves they are tight. The stuff is akin to sending new guys for a bucket of propwash.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-15-2019, 02:52 PM
Default +1
^^^ what he said ^^^
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 09-15-2019, 03:07 PM
snopercod's Avatar
I use torque seal religiously after putting a wrench on a nut/bolt. It's important because my annual condition inspections take weeks to complete and, being old, sometimes I forget what I did last week. I change colors every year. This year was blue. Oh, how rude of me. You RV guys won't know what this is. It's called a "Retractable Landing Gear". (The devil made me post that.) ROFL!
(2020 dues paid)
Old 09-15-2019, 03:15 PM
Kyle Boatright Kyle Boatright is online now
I'm a fan of having a system. Some systems include torque seal, some don't.
My "system" is based around checking torque on one subassembly at a time, beginning at one point, and ending at the far end.
For instance, if checking the FWF fuel system, I'll start at the firewall penetration and sequentially check the torque on every fuel fitting between the firewall and the carburetor on my RV-6.
On controls, I'll start the aileron controls with the nut/bolt between the aileron on one side and the pushrod, then check the other end of the pushrod on the bellcrank, then the other pushrod on the bellcrank, then... ending up all the way on the other side of the airplane, finishing with the nut holding the pushrod to that aileron.
In general, I don't use torque seal.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-15-2019, 03:19 PM
True Dan. The theory having multiple guys turning wrenches on a project is that if anyone sees the paint, the final torque was applied. We found that there was too many times one guy had to leave and the next morning the other guy picked up where the last text message said to continue. I found that in our case the TS gave a positive indicator of when someone completed a task. BTW we all got the idea from a local repair shop that does everything from 150s to jets. In our case it may have saved the day. Just thought id share. YMMV.
Mark Malone, RV7
N442MM reserved
Old 09-15-2019, 03:25 PM
PilotjohnS PilotjohnS is offline
Default Just me
I use torque seal to show the bolt or nut has been torque. But this is only as good as the process. So the torque seal goes on as the bolts are torqued if there is any doubt the bolt/nut was torqued I do it again. So if I see torque strip Then it is torqued. Often times the torque strip comes off, so I retorque before stripping.
John S
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Electrical 5% in work
Firewall Forward 5% in work
Old 09-15-2019, 05:15 PM
Wunderon's Avatar
Wunderon Wunderon is offline
could not torque seal in some cases be an indicator that rotation has occurred after the seal was applied?
Dave Grimmer
RV8 N46LG for Lynda
Flying
Edmonds WA
paid 2019
Old 09-15-2019, 06:12 PM
Ron B. Ron B. is online now
Curiousity question, I was taught that the true way to torque a nut is to have the torque reached while the nut is in motion. If you stop to ratchet the wrench and then apply torque and before the nut moves again the wrench clicks then you probably never reach the true torque value on the nut. My question is now at annual time, when you are checking torque do you all loosen all bolts and re-torque or just put a wrench on each nut and apply some torque (hoping not to go over the original torque) to see if they are really loose and are in need of re-torqueing?
Thanks Ron
RV-10 SOLD
RV-14 Flying
AirCam flying
Old 09-15-2019, 06:44 PM
Tim Lewis Tim Lewis is offline
Default +1
That?s my process, too. Torque seal used this way is a valuable aid to ensure no fastener torque steps were missed.
Tim Lewis
CFI, A&P
RV-10 N31TD - 1250 hrs
RV-6A N47TD - 1100 hrs (sold)
