Old 09-09-2019, 11:29 AM
Acrophil Acrophil is offline
Default Insurance Renewal
$293. Liability $1,000,000 / $100,000
$2109 Hull. $200,000 0$ deductible IM/NIM
$2402 Annual
Two named pilots
11,000 hr commercial with all the boxes checked. 150 in type
550 hr private with insrrument. 175 in type
These numbers make sense to the RV10 drivers?
Phil Harcourt
Bunch of others Sold
RV7A Sold
Pitts 12 Sold
Extra 300 Sold
Sukhoi 26 Sold
Twin Comanche Flying
RV10 Flying
Old 09-09-2019, 12:21 PM
kkmarshall kkmarshall is offline
Seems a bit high,just renewed 1,000,000.00/100,000.00, 180,000.00 hull
0 deductible nim/im, 1750.00 premium
2000 hrs total,375 in type,pp instrument
Keith
329DR RV10-bought flying
Continually upgrading/tweaking
Old 09-09-2019, 01:13 PM
midwest rv-10's Avatar
midwest rv-10 midwest rv-10 is offline
Default Call the gals at Gallagher for a quote
Call Leah Ringeisen @ Gallagher
They get quotes from several insurance companies and let you pick what you feel is best for you. Having two pilots may also increase the premium. Mine was $1,600 for my -10 through them. I'm 1,500hr TT and 1,200hrs in the -10 with a fresh IR. Having the IR dropped the price $300!
direct: 877-520-6247 | fax: 636-532-3646
leah_ringeisen@ajg.com
www.ajg.com/lightaircraft | www.ajg.com
Old 09-09-2019, 02:18 PM
N40ES N40ES is offline
Default INS Premium on RV-10
I'm considerably Low time at 580 HR, 10 HR in recently purchased -10 with 2 named Pilots: $1 Mil Liability, $180K Hull = $2190 Premium on my RV10 thru ( Gallagher spell-check?)
Old 09-11-2019, 07:16 PM
tjyak50 tjyak50 is offline
Pricing has been skyrocketing, especially on new policies and anything with any ?hair? on it.
Most of these are quoted electronically as we all use basically the same quoting engines.
Stick it out a few years more and things should mellow out.
Tj
Tom "Tj" Johnson, Owner (Cell: 602-628-2701)
Airpower Insurance, LLC (Experimental friendly*)
www.AirpowerInsurance.com
Phoenix, AZ
tj@airpowerinsurance.com
* IAR823, Based KDVT
Old 09-12-2019, 06:42 PM
Northernliving Northernliving is offline
Tj
I manage the insurance program for the company I work for and commercial property/caustically rates are all going up between 10-30%. For some reason the market is very tight right now. I renewed the insurance on my RV8 last month and it went up from $1264 in 2018 to $1396 in 2019. Up around 10%.
Brian J.
Boston, MA
RV8 Based at ORH - Purchased
RV8 - The Project #83313 - Under Construction
Old 09-13-2019, 05:40 AM
falcon900guy falcon900guy is offline
yeah, i got the sticker shock going from build insurance to flying insurance. was about 2400'ish dollars but had $250k hull. she said, don't worry because next year it will definitely go down. well, that wasn't so true and went up but can't imagine not getting the money i put in this airplane go down the drain if something were to happen. i was also told there is a huge difference in premiums over $200k and $250k scares insurance companies on an experimental. don't know if thats true, but i paid the premium on $250k hull.
Old 09-13-2019, 10:20 AM
Electrogunner Electrogunner is offline
Yeah, mine went up instead of down this year too.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
