  #21
Old 10-07-2017, 08:23 AM
Originally Posted by roadrunner20 View Post
Almost 4 years now still not leaking.
Going on 5 years since build and recently have several weeping rivets left tank at bottom aft flange. Not serious, just enough to make blue ring around rivets.
Have feeling this will require tank removal and aft baffle surgery to repair. It would be hard to get tank dry and push sealant uphill successfully, but considering it.
Install of aft baffle is tricky, probably pushed too much sealant down to get adequate seal. Right tank is ok - so far.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 10-07-2017, 02:01 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
Hi David,
My post was related to my previous ones in which I've gone 4 years with the syringe fixed weeper and it's still not leaking.
I've now been flying my RV 11 years now.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 10-08-2017, 10:55 PM
Darin Watson Darin Watson is offline
Default Syringe method
Due to a bee plugging the vent to my left tank and pullng almost full vacuum, I ended up with two weeping rivets, likely lifted a thin spot on the sealant. Dam glad the tank did not collapse!
Anyway, I had read this thread and thought of a bit of a modification to the syringe and loktite method. My weep was very small on each of the two rivets only getting a little blue after a week or so.
I took a 1/2? syringe and cut the tip down to about 1/16? and then stacked 3 - 1/4? o-rings glued to the syringe and together. This configuration allowed me to squeeze the loktite as hard as I could push on the syringe and the o-rings squeezed down and sealed very well.
For what it is worth I used red loktite as I only had red and blue in the tool box and red seemed a little thinner. Repeated 3 times with a day or more between to allow for the loktite to cure. Seems to have solved the problem.
Regards,
Darin
C-GULF RV-7 located in Calgary, AB
Old 10-09-2017, 04:51 AM
Saville's Avatar
Saville Saville is offline
what glue did you use> What were the O-rings made of?
thanks!
Flying RV-8 N880BC
2019 Dues - happily paid.
Old 10-09-2017, 04:08 PM
thanks!
Just used Gorilla glue and standard rubber o-rings. By the 3rd go the glue was cracking but the seal was fine.
Regards,
Darin
Old 09-05-2019, 02:45 PM
Pilotjim77 Pilotjim77 is offline
Originally Posted by Steve Melton View Post
well, not much to see but here is the offending rivet. it's been several days with a full tank (to the brim) and no weeping as was before. who knows how long it will last but I'm going to paint it and take my chances right after I finish sanding these freek'in wheel pants.
Steve, any chance you still have these pictures? I have a weeping rivet on the bottom of my left tank. Also, will this procedure work on a bottom rivet?
Thanks, Jim
Jim
Purchased July 2019: RV-6 0320 Whirlwind Ground Adjustable Prop
"We can porpoises?" -- Leo Farnsworth
Old 09-05-2019, 02:53 PM
Thanks, Jim
Yes. It will work on a bottom rivet. Mine has been leak free for almost 6 years now.
1190+ hours
2019 Donation Paid
Old 09-08-2019, 01:24 PM
Thanks, Danny.
Jim
Old 09-17-2019, 11:01 AM
bobair43's Avatar
bobair43 bobair43 is offline
Default weeping fual tank rivet
I had a couple leaking rivets . I didn't use Loctite I used thick CA glue. I pressured it in with air pressure from the outside. My rv7a n838wt was finished in 2005 tanks still not leaking. Although I think using the proseal
should work I didn't think I could thin it enough.
