Old 03-13-2019, 11:32 PM
RyanB RyanB is offline
Default Pitot Line routing
Hi Everyone
The pitot line on 4 runs initially behind the main spar and is held in place by snap bushes in the ribs. It then goes through a lightning hole in the spar and runs along the front of the spar underneath the fuel tank. My question is whilst the pitot line is running under the tank, how to you secure the line to the spar?
Another question is when you ran you conduit for the lights etc, did you run it with the pitot line and bring it out in front of the spar or run it through all the ribs to come out behind the spar?
Thank you
Old 03-14-2019, 08:24 AM
Lufthans's Avatar
Lufthans Lufthans is offline
Hi Ryan,
I can't remember how the pitot is held in place in ours, sorry. It is indeed running between the spar and the fuel tank, that I do remember.
On your second question: The wiring for the lights on ours runs aft of the main spar all the way and ends with a connector on that side.
Good luck!
Hans
Hans Teijgeler
Hilversum, The Netherlands
Resurrecting an RV-3B
PH-BRR Bowers Fly Baby; Imported and upgraded
PH-MGA Jodel DR1050; Built, with Subaru EJ25
PH-SUM RV-4; Imported and upgraded. Sold my share :-(
PH-EIL RV-4; Imported and upgraded for friend. Sadly crashed
PH-ERD Robin DR300; Built with Subaru EZ30 for friend.
Old 03-14-2019, 09:36 AM
Default Pitot
Thank you so much Hans, really appreciate the help
Old 03-14-2019, 10:47 AM
lr172 lr172 is offline
On my 6A, I used plastic tubing. It was supported near the pitot connection, but left it loose behind the fuel tank. The plastic will see no negative affects from constant flexing and bouncing around, like an aluminum line.
Larry
Old 03-14-2019, 11:26 AM
dwrichey's Avatar
dwrichey dwrichey is offline
I would be concerned about allowing a pitot or static line (plastic or metal) to go unsupported between the fuel tank baffle and wing spar. Vibration will eventually wear a hole in either. I suggest passing the lines through snap bushings installed in the rib root area, near the spar.
Old 03-14-2019, 01:18 PM
Default Pitot
Thanks for the replies guys. Sadly where the line runs behind the tank it just runs between the tank baffle and the main spar, so no ribs there to drill through for support. I was thinking of maybe just prosealing the line to the spar?
Plastic lines could work well!!
Old 09-03-2019, 01:12 PM
MS1095 MS1095 is online now
RyanB
What did you end up doing? Pictures?
Old 09-03-2019, 08:55 PM
Yen Yen is offline
I made clips to hold the wiring and also the pitot tube to the front of the min spar, held on with pop rivets.
Old 09-06-2019, 02:43 AM
Default Pitot
Hi there
We did the same, made some simple P Clamps out of 0.020 Ali and drilled a 3/16 hole in the clamp. We then used the bolts that hold the ribs to the spar to hold the clamps. In other words substituted the bolts washer with the Ali clamp.
We put some pro seal on clamp and tube before bolting on to prevent rubbing.
Hope this makes sense
Old 09-08-2019, 07:28 PM
If you plan to use an EFIS with a remote ADAHRS, scrap the per-plans routing. Use the plastic lines and run them behind the spar, under the seat, and aft to where you will likrly mount the ADAHRS. I spent a bunch of time making some very nice aluminum lines on my 6, didnt end up using them at all. It is a PITA to try and route then back through the spar.
Here is how I secured the aluminum lines to the front of the spar. This method is called out on the -6 plans.
http://www.mykitlog.com/users/displa...g=91662&row=29
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
