08-29-2019, 09:45 AM
drilling out pop rivets
put a stop on the drill bit so only 1/4'' of the bit is exposed. when outcomes aren't so good drilling out pop rivets often it is caused by the longer bit ''wallowing'' out the hole either as it drills thru or as you pull it out of the hole.
Bob Noffs
n. wi.
dakota hawk/jab 3300 built and flying. sold 6/18.getting serious about the 12. in the hangar now as of 10/15/19
RV-12 kit as of 9/13
08-29-2019, 09:47 AM
Wasn't sure if you were asking or telling but this does the job - https://www.aircraftspruce.com/catal...driv-03368.php
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
08-29-2019, 11:29 AM
You?re drilling too deep. Drill only to a point you can pop the head off. Then gently punch the remainder out.
Sometimes the stem breaks off flush with the head or not very deep when the rivet is set. You can gently punch the stem down if you have a solid enough structure. Then drill off the head and punch out the body.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
08-29-2019, 11:35 AM
Originally Posted by bkervaski
That is for dome head bucked rivets. Are you saying it works for pop rivets too?
Scott Black
VAF dues 2020
Instagram @sblack2154
08-29-2019, 11:38 AM
Oops! Looks like this is the kit I was referring to:
Sorry for the confusion, updated the link.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
08-29-2019, 12:14 PM
I always punch the stem out first and then drill the rivet out with a slightly undersized bit.
If the stem is in and the drill hits it, it will wonder. If the stem is not there, you shouldn't have any issues.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
08-29-2019, 12:43 PM
I use a center punch to drive the mandrel, but only to where it's low enough that the drill won't touch it, then drill just to pop off the head. Use the centerpunch again to push the mandrel out the bottom. Too easy.
Always use a backup block on the mandrel side to prevent distorting the workpiece.
John Halcrow
Tustin, CA
RV-12 120682
Emp/TC done; Wings done; Fuse kit done
"History teaches us that men and nations behave wisely once they have exhausted all other alternatives." --Abba Eban
Paid up until Aug 2021
08-29-2019, 02:27 PM
John,
Did you find a spring-loaded center punch narrow enough to fit in the hole in the rivet where the stem is, or did you have to modify a punch to get it to work?
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
08-29-2019, 07:48 PM
No mod needed - works a treat out of the box. Use the lighter duty 'aluminum' punch. I have a ?" diameter blind hole drilled in a UHMW backup block to catch the mandrel.
John Halcrow
Tustin, CA
RV-12 120682
08-29-2019, 11:42 PM
Thanks, John. I'll have to look around for a smaller one. The diameter of the one I have is too big and can't reach the stem inside the hole.
Mark
RV-12iS Fuselage
RV-9A Project: Sold
