08-23-2019, 07:40 PM
Aerosport overhead console install question
When installing the Aerosport overhead console, what has everyone done to handle the backing strip for the rivets on the final rivet install since the center part of the cabin top will be unavailable for the strip?
I am considering getting it all drilled then epoxy it to the cabin top before installing the console. Will that work?
Michael Marchand
Washougal, WA
Dues paid: 2015, 2016, 2017
N910DM Reserved
RV-10
Empennage - Completed!
Wings - Completed!
QB Fuse In work!
08-23-2019, 08:57 PM
I believe I used proseal to hold it in place then used poprivets to finish.
Dave Ford
Cadillac, Mi
08-24-2019, 05:12 AM
Can you post a photo or snippet from the plans? I?m not sure what you?re referring to by your description.
The mold was made off my cabin cover, so I was on of the earlier implementations of the overhead console.
I don?t recall deviating at all from the Van?s rivet schedule in the plans.
08-24-2019, 10:12 AM
After drilling it, I cut the backing strip into three pieces. The center piece was held in place with clecos when I mount the console to the top. To install the skin aft of the cabin top, put a couple of pieces of tape to hold the center portion of the strip and pull out the clecos if the strip is not already secured from the console bonding process.
Larry
08-24-2019, 12:04 PM
The callout for the rivet line that is covered by the console is for CS4-4 pulled rivets.
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
08-24-2019, 01:47 PM
and it also calls out an aluminum backing strip to support the inside of the cabin top for those rivets, which I believe is what the OP was asking about.
08-24-2019, 02:57 PM
It?s simple to cleco the backing strip in place and then pull the rivets. I?m having a hard time understanding what the problem is I guess.
Randy P.
1st time builder
Reserved:C-GRPY
08-24-2019, 06:47 PM
As I recall, I was able to slip the backing strip between the overhead console and the inside of the fiberglass top, and then rivet per the plans. I may have left a small section of the cabin top at the aft end without glue to allow the strip to slip into that area, but don't remember.
Dave Macdonald
RV-10 First Flight April 1, 2020.  Currently in Phase 1
2020 VAF Dues Paid
08-24-2019, 07:00 PM
That's what I did.
The strip will get covered by the Aerosport cabin trim.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
08-24-2019, 07:41 PM
A picture
Yep, it's really not a problem. Here's a picture of my cabin top just as it was ready to go on permanently. You can see the strip sitting in position at the rear, held in place by a couple of clecos. Five minutes after this photo was taken, the top was on. I've posted a link so you can get the full resolution photo:
http://www.tasrv10.com/?attachment_id=2318
Regards,
Adrian
Adrian Port
RV-10 emp done, wings 90%, fuse 90%, cabin top DONE!
www.tasrv10.com
