Old 08-19-2019, 12:52 PM
ALagonia ALagonia is offline
Default Catto LET (leading edge tape)
I am considering applying the Catto LET, leading edge tape, to my three blade Catto prop. It is claimed to help or prevent erosion to the leading edge of the propeller blades.
Does anybody have any experience using this product? And if so what are your thoughts? Does it work as claimed, are you glad you did it, would you do it again on another Catto prop?
Thanks in advance for any and all comments.
Old 08-19-2019, 01:42 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Have flown 500 hours, through occasional rain and occasionally off grass and gravel strips. The tape is a bit scuffed and nicked in places but the underlying prop is in perfect condition.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 08-19-2019, 02:04 PM
Thank you. That is exactly what I was hoping to hear. Was it hard to put the tape on?
Old 08-19-2019, 02:46 PM
roadrunner20's Avatar
roadrunner20 roadrunner20 is offline
I use LE tape & have also found it protects my vintage 2005 prop's leading edge from nicks & rain damage.
Danny "RoadRunner" Landry
Morphed RV7(formally 7A), N20DL, PnP Pilot
1190+ hours
2019 Donation Paid
Old 08-19-2019, 02:52 PM
MarkW's Avatar
MarkW MarkW is offline
I have Craig's three blade with nickel leading edge but he also puts the tape on the inboard section of the blades where the NLE is only on the last 12" of tip.
My tape has held up well with 450 hours and lots of rain. If I didn't have the NLE I would sure use the tape on the entire edge.
Mark
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 08-19-2019, 03:34 PM
sirlegin's Avatar
sirlegin sirlegin is offline
I use LE tape on the entire leading edge of my 3 blade Catto and change it every other annual or unless it needs it earlier. Harder to get off the longer you leave it on in the Texas heat.
Nigel
RV9A-N113SQ
52F
Old 08-19-2019, 04:22 PM
This has been great info. Placing my order right now.
Thank you all for responding. This site is awesome when forced with a decision to make.
Old 08-20-2019, 09:51 AM
FORANE's Avatar
FORANE FORANE is online now
Tape works well at preventing rain erosion however...
It is hard to get the tape to adhere to the curved tip of the blade without buckling and failing in that location.
Due to the above, the tip is unprotected and erodes on the leading edge.
After one good flight through rain, my experience is the tape gets damaged to the point that it requires replacement.
I have an older 3 blade Catto on my garage wall due to too much leading edge damage flying through rain, mist, etc. If it were one of his newer ones with the nickel leading edge, I would likely still be flying it today.
Lancair 235/340
RV-9A (2013 - 2016)
Old 08-20-2019, 04:02 PM
Ordered the LET today for my three blade Catto prop without NLE.
Old 08-21-2019, 10:33 AM
lr172 lr172 is offline
I used a prop tape from Spruce and followed Catto's installation guidelines. Not sure which one - would have to look it up. I have flown through rain many times, always at 2700 RPM. It works and would not even think about flying through rain without it.
I am told the tape costs about 3 knots and I saw a reduction after applying it.
Larry
