Old 08-20-2019, 05:18 AM
cccjbr6 cccjbr6 is offline
Default adding 4th seatback piano hinge
This is a question from a non-builder. We are about to add the Almost 14 Seatback mod which will allow the seat to recline more, but I also want to add more legroom. Is there any reason structurally or otherwise we cannot add a fourth row of piano hinge to the seat pan on both sides to add another 1.5 inches or so of legroom? I don't know what is under the seat pan that might interfere with that new row of rivets. I would appreciate any thoughts and guidance.
Chris Kimble
Birmingham Alabama
RV-6A Bluebird- Beautifully built by Bob Axsom and maintained by Vic Syracuse
$10/month donation gratefully made (worth every penny and painless)
Old 08-20-2019, 06:40 AM
I found that the seat belt brackets prevent much more aft movement of the seat hinge point. The additional recline does improve legroom as well. I am 6'4" and have long legs. I have the pedals as far forward as they can go, the 14 mod, plus thin back cushions, I fit great.
That said, there is nothing else to proclude adding another hinge. I bought some of the 20 degree bent triagle anchors to improve seat belt geometry.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 09-05-2019, 08:33 PM
MWH265's Avatar
MWH265 MWH265 is offline
Default Adding Hinge
I did it on my 6A. Just on the pilot side. Also did the almost a 14 kit. Seatbelt attach points are very close. You may need to change the attach brackets on the belts. Or, you could just go 1 inch instead of the 1 1/2 that would even space the 4 row. So far no adverse effects. W&B still within envelope.
RV6A Owner/Operator
Old 09-06-2019, 09:51 AM
Raymo's Avatar
Raymo Raymo is offline
Easily done but, as mentioned above, the seat belts are the limiting factor. I gained about 1.5" in my -7A with Crow harnesses.
Ray
