  #161
Old 07-18-2019, 10:46 PM
jpowell13 jpowell13 is offline
Default LIGO
Nice pics Bert. A friend in Baton Rouge wanted to fly over LIGO then do the guided tour. We did both. The legs are each 4km long. When gravity waves pass over the facility the length of the legs is changed and the laser interferometer measures the difference in length between the legs. The difference due to gravity waves is less than the width of a proton. That's a new standard of precision for even the most ocd RV builders to think about. John
Old 07-19-2019, 07:03 AM
Paragon Paragon is offline
Very interesting pictures of LIGO.
I've read a description of all the data postprocessing required to extract a signal from the LIGO data. The device is an exceptionally sensitive seismometer. One has to somehow subtract out all manner of signals many orders of magnitude larger than any gravity wave signal, in order to detect the desired gravity waves. This also includes removing test signals at multiple frequencies always present(?). Then also comparing to signals from the other LIGO sites to verify proper timing of signals given their geological distances apart, and the orientations of their sensor legs re. the possible orientations of incoming gravity waves.
Yes, they are literally trying to measure changes in length smaller than a proton, over a baseline leg length of miles.
I've read a European technical paper which independently analyzed the initial gravity wave detection data, and concluded it was impossible to statistically state that an actual gravity wave signal had been detected, as opposed to resonances between test signals.
A very difficult scientific proposition, and a data postprocessing nightmare, upon which literally billions have been spent. Difficult to say whether this is an amazing breakthrough, or a boondoggle of epic proportions...
-Paragon
Cincinnati, OH
Old 07-20-2019, 04:45 AM
NYTOM NYTOM is offline
Default Harbor Freight must have them ?cheap?
Now can I just get a proton tape at Lowes or do I have to spend more and upgrade to a proton steel rule. Measure twice, cut once.
Tom Norwood
Classic "Short Tail 6A N822PM
TMX-O360. Phase 1
Old 08-14-2019, 05:05 PM
R-5314D
Old 08-14-2019, 05:40 PM
DanH's Avatar
DanH DanH is offline
The top photo is the Air Force target area in 5314A. Zoom in and be amused. You know you made a wrong turn when your GPS highway nav puts you on "Strafe Road", the dead ends at far right
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-15-2019, 08:33 AM
John Tierney John Tierney is offline
Looks like the Dare Co Bombing Range near Kitty Hawk.
John Tierney
Vonore, TN
RV-7A - N777JT Flying
Old 08-15-2019, 06:35 PM
JordanGrant's Avatar
JordanGrant JordanGrant is offline
Default Ahhh, the memories
I've dropped many a little blue bomb on that range. I've even been supersonic over the Alligator river on the way in...unintentionally. Lots of fun!
Jordan Grant
RV-6 N198G
Monthly donation started Mar '20
Old 08-15-2019, 09:01 PM
Intruder Intruder is offline
Top photo is Air Force Dare bombing range and with the trees cut back, looks like a .45 caliber bullet. The bottom is Navy Dare bombing range and it has a key hole shape. That is how you can tell the difference visually and on radar. The circle part of the Navy range had lights around the perimeter, just like the houses on the shore surrounding Stumpy Point Bay (the circular bay just past the ranges). Easy to get mixed up doing low level pop-up night dive bombing on a very dark night (don't ask how I know).
John Stoll
RV-8A under construction
Summerville, SC
Old 08-16-2019, 04:36 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Default Memories
I put a lot of lead on that ground. Some of which actually went through the target! Came up to Dare from Myrtle Beach AFB (closed now), flying the A-7Ds (retired now) in 1974-77. I'm really starting to feel old now!
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 08-16-2019, 10:45 AM
Gadget15e Gadget15e is offline
Default Good Memories!
Beautiful photos! At first glance, it was ?I?ve seen that before.? Dropped a few BDU-33s, BDU-50s, and even exercised the M61A1 there flying with the 335th FS Chiefs 1995-1998. Wow, that was already a long time ago
