Originally Posted by 49clipper
I talked to AirMaaster at OSH and they informed me the new drive motor is faster and it has been flown aerobatic. I am done with aerobatics at this point in life, but I am putting one my current build. (not an RV)
Bud is a great guy, but he is also owner and chief salesman for his product. My guess is that he said something VERY similar to what you said and that his statement is literally true - their props probably do pitch faster than MT props (their only real competitor for higher horsepower electric props).
When you do a loop, in the downward portion your speed can build VERY quickly. Hydraulic props change pitch so fast you are unlikely to overspeed; electric ones would likely require you to yank the power to prevent that, then push it back in approaching the bottom of the loop.
I've done some aero with both fixed and C/S hydraulic props. Treat it like a fixed and you will >probably< be ok.
