Old 08-13-2019, 08:51 AM
Keldog Keldog is offline
Default Dynamic Prop balancing
Anyone have a line on Dynamic Prop balancing in the Northern California/Sacramento area?
Old 08-13-2019, 09:18 AM
jrtens's Avatar
jrtens jrtens is offline
Try Rainbow.
https://rainbowaviation.com/
Jon
12iS SLSA
Salt Lake Int'l
Old 08-14-2019, 06:50 AM
randylervold's Avatar
randylervold randylervold is offline
moderator
I?m familiar with balancing Lycomings, can anyone advise the procedure for a Rotax? There is no starter ring (aka ?flywheel?) to attach the weights to, where are the weights normally installed?
Randy Lervold
RV-12iS, empennage/tailcone complete, wings currently, fuse in box
RV-3B, first flight 2007 - sold
RV-8, first flight 2001 - sold
Old 08-14-2019, 07:05 AM
Walt's Avatar
Walt Walt is offline
Drill holes and add weights to the spinner bulkhead.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 08-14-2019, 07:31 AM
moderator
Hmm, would it make sense to drill a series of evenly spaced holes near the perimeter in during construction to provide for this? Maybe Van's should add this to their design?
Randy Lervold
Old 08-14-2019, 07:39 AM
Walt's Avatar
Turbines do that but you would need to account for the loss of material as most of the holes would remain empty.
Old 08-14-2019, 08:55 AM
jask jask is offline
As long as the holes are symeterical, it should make zero dfference.
RV-7 builder Ramona, CA.
Free prop balancing for Vans owners
(I am not in the business of prop balancing, just as a courtesy to meet other owners.)
Old 08-14-2019, 08:57 AM
rongawer rongawer is offline
I actually prefer drilling them myself. Using pre-drilled holes often requires splitting weights, whereas drilling the hole allows precise location of a single weight.
Use a #13 drill, and then a 3/16" ream to ensure a close tolerance fit for an AN3 bolt. Works well.
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"...many great hours and happy landings so far.
- Several others that are now just great memories for me.
Old 08-14-2019, 08:58 AM
Walt's Avatar
I was referring to the loss of material from a strength/structural stand point.
Old 08-14-2019, 09:05 AM
Walt's Avatar
99% of the time I split weights so that you can tweak the solution, it's difficult/almost impossible to precisely nail the exact angle with a single hole. The ease of splitting weights with some machines is much easier than with some more basic units.
