Go Back   VAF Forums > Model Specific > RV-3
  #11
Old 10-18-2011, 09:03 AM
DarylT's Avatar
DarylT DarylT is offline
Default Threaded Fittings
The ones from Aircraft Extra are threaded for an AN3 bolt. I am using a remove before flight flag on a drilled headed bolt. Still doesn't solve the wing flange issue that Paul describes though. But they work great on the side by sides.
Daryl Tolliver
VAF 1086
Yes: I paid my =VAF= membership dues for 2020
RV-7A - N754RV: Status - Pink Slip is In! First Flight 8/23/12 - My First Flight 9/24/12!
Home from GloCustom for Paint! 3/16/13
957 hours and climbing
7th Condition Inspection complete 10/31/2019
Superior XP IO360 (180 HP), Hartzell Blended Airfoil, AF-5400 EFIS panel, Garmin Aera 660, TruTrak Vizion 385 AutoPilot, Dual Pmags
Houston, TX
Track: SPOT
Weiser Airpark (EYQ)
http://www.rv7a-factory.com
Old 08-04-2019, 03:58 PM
mfleming's Avatar
mfleming mfleming is online now
I thought I'd revive this old thread.
I'm getting ready to to make my vent lines for my -7 and I thought the OP may like to update us on how this method worked for him. It looks much simpler to construct and I like the idea of minimizing the fuel lines in the cockpit.
If Paul is busy flying his little jet around , maybe someone else could lend their experience with the coiled vent method.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Donated for 2020 and so should you
Old 08-04-2019, 04:49 PM
Captdf's Avatar
Captdf Captdf is offline
Four years ago I was rebuilding an already-built RV4, and I needed to replace the vent lines inside the fuselage due to damage. I decided to try the ?F1? vent installation because it was easier to accomplish than replacing the internal lines.
The F1 vent system spits more fuel on the ramp than the original installation did and seems to vent more fuel at high AOA. At my next condition inspection I?m planning to re-do the system and go back to the vent system as shown on the plans.
Dru Fisher
RV-4 N100DF
Gloster Aerodrome, Sealy, TX 1XA7
ATP, CFII, A&P, I.A.
EAA Tech Counselor
EAA Flight Advisor
Old 08-04-2019, 05:08 PM
steve lenne steve lenne is offline
Default Fuel vents
I used Paul?s vent suggestion and is working just fine on my rv3b.
Steve
Rv3B
100 hours
Old 08-04-2019, 07:34 PM
FinnFlyer FinnFlyer is online now
Default Outboard vent
Why carry the vent line all the way through the tank and through the root rib?
Seems the simplest installation would be a 90 degree fitting in the most outboard tank rib at highest point and straight down and out a hole in the tank/wing skin with a 45 degree cut on outside end.
Or a fitting in bottom outboard tank skin with inside tube going to the highest point in the tank (a bit more drag from fitting).
I chickened out and did the conventional RV-4 installation because of these unknowns:
Vent hole could ice over? (no hot engine air passing over vent opening)
RV-4 is a taildragger (is it possible to get inside end of vent line at a point where fuel won't siphon out with full tank tail up and tail down?)
Less drag with inboard vent? (already turbulent air from engine and gear)
I understand the RV-10 has a straight down vent with no loop.
Finn
N214FL RV-4 -- Building
N46AZ RV3-B Mazda 13B EFI -- Bought -- Flying
N993FL RV-3A Mazda 13B NA 575 hours
Old 08-05-2019, 05:12 AM
Larry DeCamp's Avatar
Larry DeCamp Larry DeCamp is offline
Default Full tanks
I have the Rocket/Dye/etc two loop system on 3B. It works very well for me because I normally store the ship with tanks half full. When topped of for travel, I have not noticed anything objectionable ( gas odor). Completely full, sloped ramp or hot sun is ?no win scenario?. That said, Fynnflyer?s idea for outboard vent at the apex of the airfoil would optimize the condition, but only on perfectly level ramp if ?no leakage? is the objective. Just my $0.02.
Larry DeCamp
RV-3B flying w/7:1 0320 / carb / Pmags / Catto 3b / digital steam
RV-4 fastback w/ Superior roller 360/AFP/G3X/CPI/Catto3b
Clinton, IN
Old 08-05-2019, 05:21 AM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
I implemented a slightly different version of this in my -8. Works great. I've never seen a drop of gas in almost 200 hours. I would definitely do it again
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 08-05-2019, 10:09 AM
mfleming's Avatar
Sounds good, what was the slightly different version...Photo??
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
Old 08-05-2019, 05:35 PM
scsmith scsmith is offline
The Lancair folks run the vent line out to the wingtip and then down to an NACA inlet in the bottom of the wingtip to supply some elevated pressure. But also, they put a check valve in the line, so air can get pulled in to replace fuel as it burns, but fuel can not come out the vent.
I don't know if the check valve has a pressure relief function, so that expanding fuel in a full tank in the sun won't overpressure the wing?
If you were to omit the check valve and just run the vent to the tip, as I think FinnFlyer is suggesting, only slight mis-coordinated flight would send a substantial amount of fuel flowing out the vent line. A few moments in a slip with a 5-degree bank and you could lose 1/4 tank!
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 08-05-2019, 07:54 PM
No, no. Just like the newer RVs have a vent line straight down at the tank root rib, I was thinking straight down at the outermost tank rib. Or a 90 degree fitting on the tank bottom facing into the wind, and inside the tank a tube from fitting up to very highest point in the tank. No reason you couldn't coil that tube a few times inside the tank too.
Of course the ultimate in simplicity would be to drill a 1/4" hole in the fuel cap and press a 1/4" tube, bent 90 degrees into the wind, into the cap But that would attract a lot of dirty looks from other RV builders and owners and cost you at least 10 mph top speed.
Finn
