  #11
Old 08-01-2019, 10:23 AM
DanH's Avatar
DanH DanH is offline
Originally Posted by Bill Boyd View Post
This raises several questions/ issues. What is the recommended procedure for breaking in the brake linings?
I recommend not doing it.
Seriously, I quit the break-in procedure and couldn't tell any difference. They will settle in with normal usage. If the first few flights are off a runway so short that the last few percent of pad performance is critical, it's the wrong runway.
Dan Horton
RV-8 SS
Barrett IO-390
Old 08-01-2019, 10:53 AM
fl-mike's Avatar
fl-mike fl-mike is offline
I came to the same conclusion. I just land a little hot and apply medium hard braking to "condition them" the first time out. Seems to be about the same as a low-speed 1700' taxi at 1700rpm. I did something to my last pads as they would no longer hold at run-up, so I replaced them and did the above procedure and everything is back to where it should be.
Mike W
Venice, FL
N164WM
Old 08-01-2019, 11:02 AM
Bear Creek Skunkworks Bear Creek Skunkworks is offline
Default Brake fire
We have fixed this very thing at my shop. Count your blessings that you didn?t run into something and have a prop strike. I would fix it my self or have others fix what I didn?t have the knowledge, skill, and ability to do and would not file an insurance claim. I have an assortment of used wheels, brakes, calipers, and tires which I would sell reasonable. I also have a new complete never installed left wheel pant kit if that is the side you damaged. Going with the diy approach it won?t be that bad. Line up some buddies, with experience, to help with the pant installation
Happy to help call if you wish to discuss further,
Terry
Terry Gardner
EAA Technical Counselor
A&P IA
Light Sport Repairman, Airplane, Glider, Powered Parachute, Weight Shift
CTO
Old 08-01-2019, 11:08 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I?m With Dan - I stopped doing brake break-in decades ago, and usually get several years out of my brake pads on all of my taildraggers.
Just my experince.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-01-2019, 11:41 AM
Bill Boyd's Avatar
Bill Boyd Bill Boyd is offline
I'll make a note of Dan and Paul's opinion - and scratch that off my 1st-flight readiness card. Brake fire is an experience I don't need.
Bill Boyd
Hop-Along Aerodrome (12VA)
RV-6A - N30YD - Built '98 / sold '20
RV-10 - N130YD reserved - under construction
donating monthly to the VAF - thanks, Doug
Old 08-01-2019, 12:51 PM
flyboy1963's Avatar
Default ask the insurer?
just another data point; I had a non-aviation claim, and the insurer would not let me buy a used gadget, even if under the replacement max. value!
They absolutely insisted on an invoice from a business for a new gadget.
It turned out ok for me, but eliminated the option to 'fix it myself'.
check with the insurer, that might just answer a few questions.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 08-01-2019, 01:54 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Exclamation Don't
I would say "don't file a claim". I ran into this with my glider. My first claim was small. I asked the insurance company if I should file or not. They said, of course, that is what we are here for.
This happened twice more. Same question, same answer. So 3 claims over about 6-7 years.
One year, I didn't get renewed. They said the underwriter wouldn't renew me because of multiple claims. I said, "but I asked each time, and you said to file". I ended up getting a call-back from the owner apologizing for what occurred, but he could not change the underwriter's mind.
So I tried to get new insurance. They ask: Have you ever had previous claims? Note, they don't ask "in the last x years". So I have to answer yes. Then they ask: Have you ever been dropped by a previous insurance company? Again I have to answer yes.
So, the long and short of it for me, is avoid the claim unless you can't afford the repair.
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on final wiring and the engine
84CX Reserved
Old 08-01-2019, 02:36 PM
RV6_flyer's Avatar
I have been doing the same thing for over 20-years. The RV is too light of an aircraft to use the recommended taxi procedure.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 08-01-2019, 02:41 PM
RV6_flyer's Avatar
Originally Posted by Imbeccad View Post
Hi guys-
Recently had a brake fire, from a recent brake lock up after landing and during taxi, on my 6A...
This resulted in the tire, wheel pant and fairing, brake lines at the wheel and possibly the brake assembly burning up fairly good. We are waiting to hear from a mechanic, but anticipating that the cost to fix might be between 3-4K. Trying to figure out the best route, pay out of pocket or file an insurance claim (no deductible). I?m new to all this, so if anyone has any thoughts I?d love the feedback and to hear if anyone has been in this same boat.
Secondary- does anyone have any experience with a brake fire- any salvageable parts? We probably had close to a minute of fire exposure.
Thanks again!
Becca
I saw the after fire results of an RV-8 brake fire. The wheel and brake caliper were still good and reusable. The Wheel, brake, and caliper are the expensive parts. IF the wheel and caliper are good, I would NOT file an insurance claim.
The insurance company is in business to make money. You will pay for the repair either by the actual cost or in higher insurance premiums.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Old 08-01-2019, 02:46 PM
dreed dreed is offline
:-) I think he gets a pass on that work travel.
Where are you located? I bet some fellow RV'er/VAF member is willing to help you out.
Dan Reed
Camas, WA
RV-7A - Slider in progress - N167DR (reserved)
Sitting in the paint booth, then final assembly/inspection time
2018 and 2019 VAF dues paid
