Old 07-27-2019, 08:14 AM
Charles in SC Charles in SC is offline
Default James cowl wetsuit boot question
Fabric in or out or did you use something else?
Thanks in advance!
RV 7
Old 07-27-2019, 08:43 AM
db1yg's Avatar
db1yg db1yg is offline
Default SJ Nozzle Fabric
I did mine fabric out to provide the smoothest possible surface for internal air flow. This was done back in 2006 although I have replaced with new once.
Cheers
db
Dave B.
RV9a/ECiIO360/James Cowl/WW RV200 Prop
Flying since 3/06 and still smiling!!!
Old 07-27-2019, 10:23 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Fabric out. Less likely to wear the rubber as compared to the hose clamps against the rubber on the outside.
Carl
Old 07-27-2019, 04:49 PM
Thanks, that is what I was thinking.
RV 7
Old 07-27-2019, 08:16 PM
sjhurlbut sjhurlbut is offline
Default Boots
I use silicone tubing. Clamp on one side of you wish but let it able to move.
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
Steve "Stu"
Cold Lake, Alberta
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - Fastback - built - sold
4 #2723 - building
Old 07-28-2019, 06:01 AM
BillL BillL is online now
With the fabric thing all covered, there may be more for you.
The hose clamps did not seem to like saying put. I used the same urethane glue as bonding the neoprene ring to bond it to the inlet ring.
My axial gap is about 1/8". The diffuser side is left to float. Install and removal is rolling up the boot like a shirt sleeve and pulling out the ring. My inlet ring is the same. Roll it up before installation of the cowl, then reach down and unfurl it with a nice snap.
Bill
RV-7
Lord Kelvin:
Old 07-28-2019, 12:38 PM
Don Jones's Avatar
Don Jones Don Jones is offline
You also might want to support the seam in the material after it's glued together to make the tube. Both of mine began splitting at the seams. I used some black cloth that matched the cloth on the wetsuit material and glued it over the seam. They have been solid since. It wasn't the glue joint failing, but the foam was tearing next to the joint.
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 07-31-2019, 06:23 PM
Thanks for the comments, I did put a reenforcing doubler strip on the joint after gluing. I am undecided about what to use for clamps. I do not like the worm drive hose clamps because they can cut into the wetsuit very easily. Any other tip are welcome!
RV 7
Old 08-01-2019, 06:34 AM
jhk770 jhk770 is offline
Default Sam James wetsuit material
Anybody know a good place to buy this material besides Sam James? I?d like to get a roll and replace my aging ones.
Thanks, Jim
Old 08-01-2019, 06:55 AM
dpansier's Avatar
dpansier dpansier is online now
Amazon has several types of wetsuit fabric available in assorted sizes.
Don Pansier
Green Bay, WI (GRB)
RV-7 N450DP
W9LYX
Antennas for Experimental Aircraft
www.deltapopaviation.com
