  #11
Old 07-29-2019, 09:50 AM
Steve Melton's Avatar
Steve Melton Steve Melton is online now
Originally Posted by Jpm757 View Post
The "A" models are more than capable to operate out of soft/unimproved strips, not quite as rugged as conventional gear models, but still up to the task. Unfortunately "some" of our nosewheel friends do not have a clue as to proper soft field operations. Thorough soft field training is essential to staying out of trouble.
maybe a pilot having a bad day or a gust of wind or something else could trigger a chain of events.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
Old 07-29-2019, 08:57 PM
mturnerb mturnerb is online now
Safety isn't just about better pilots/piloting. It can and should include equipment fixes/improvement where a design has a weak point, or as you have suggested, operational adjustments to reduce risk of failure. One of the reasons I chose the -14A is the much more robust nose gear: I hope my skills/technique are enough to never test it but why not take advantage of every opportunity to mitigate risk?
Turner Billingsley
RV-14A built/sold N14VB
RV-10 in progress as of May 2020
https://tbrv10.blogspot.com/
https://turnerb14a.blogspot.com/
Old 07-29-2019, 09:37 PM
Captain Avgas Captain Avgas is offline
I agree with this comment. There is another thread running on VansAirforce at the moment about an in-flight fire on an RV14A east of Salem that resulted in an emergency landing into a farmer’s field. The interesting thing about that incident is that the beefed up RV14A nose gear with the shock absorber appears to have been robust enough to prevent the aircraft from tipping upside down. If the aircraft had gone over and trapped the pilot inside with the plane on fire the outcome might have been dire indeed.
I did transitional training with Mike Seager so I know what is required to keep the stress off my RV7A nose gear. But I dread the thought of an engine failure leading to an off-field landing on a less than perfect surface. The RV7A nosegear is very fragile and when it fails the plane almost always tips over...that’s the reality. It was good that Vans finally re-engineered the 7A nosegear, but it was 10 years too late.
Bob Barrow
RV7A
Old 07-29-2019, 10:38 PM
jcarne's Avatar
jcarne jcarne is offline
Interesting take on that accident, I hadn't thought about that before. One more reason I'm glad I upgraded.
Jereme Carne
PPL
RV-7A Emp. done
Wings done
Fuselage done
Finish kit almost done
Exempt but gladly paying!
Old 07-30-2019, 03:50 AM
KatanaPilot KatanaPilot is offline
Talked with both Rian Johnson and Gus Funnell at OSH about the improved nose gear design. When they asked how far along my project was and I stated "flying", they both in unison stated unequivocally "don't do it".
Their comments were more about the level of complexity of converting a flying airplane. Specifically about the amount of working re-doing baffles (I have a BL plenum) and the likelihood of extensive cowling rework. Additionally, there may be some issues of interference with accessories on the firewall and concerns of exhaust routing.
As to the new nose gear design - you don't need to be an engineer to understand the improvements over the old design. As they both stated, the original design met Van's criteria of light, functional and inexpensive - but the new gear is a lot more robust.
We are still going to do the mod later this year...
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2
RV-10 under construction at Synergy Air South
Old 07-30-2019, 08:18 AM
AlexPeterson's Avatar
Perhaps instead of rehashing the same old arguments about nose gear this or that, it might be helpful instead to find out what sort of axle/bearing adjustment design the subject airplane had. Since people started changing to a solid axle design some years ago (as was the design in the early models of 6A), the reported incidences of nose gear tuck-unders appears to have dropped significantly.
If anyone has knowledge about or access to this aircraft, it would be very good to learn about this detail.
See this thread for more about this.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 07-30-2019, 08:57 AM
N42AH's Avatar
N42AH N42AH is offline
Default Middle of Nowhere
Talk about a long way from initial medical services.
Two hour drive to William Creek Airfield for ambulance crew.
Originally Posted by SPX View Post
Pretty good article with two photos:
https://mobile.abc.net.au/news/2019-...field/11354666
Steve Crimm
Gilbert, SC
Based - SC99
RV-10 N42AH
RV-9A N42AH - SOLD
Europa Monowheel XS N42EU - SOLD
BH-206B3 N42AH- SOLD
BH-206B3 N43AH - SOLD
Track N42AH/N1FLY
Old 07-30-2019, 10:03 AM
newt's Avatar
newt newt is offline
that nose wheel should only be used on hard surfaces. if you land on soft fields get the upgrade. Van's should really make that a service bulletin.
William Creek is a well-maintained hard surface (bitumen) runway, so I don't know why that's relevant here.
- mark
[ Paid up on 3 Feb 2020 ]
RV-6 VH-SOL
Old 07-30-2019, 01:13 PM
Hornet2008 Hornet2008 is offline
Most outback runways are in really good condition the flying doctor uses them. Mate and I visit many outback bitumen strips and are suitably impressed by the condition of them. Hungerford pop about 15 has a fenced bitumen runway for the Royal Flying Doctor Service King Air. The fence is to keep kangaroos and emus out.
Pete
RV-9 "Cloud tinnie"
Registered VH-EAB
Flying Phase 2
Old 07-30-2019, 02:55 PM
airguy's Avatar
airguy airguy is offline
- mark
Maybe, but the photographs show the airplane sitting on a dirt strip.
