07-17-2019, 07:55 AM
Rotax Compression Check
Don?t own a Rotax but curious.
Noticed a post calling out compressions of 82/85 etc. on a 100 hp Rotax. Question is are Rotax compression checks done at 85 psi? Most other aviation engines are 80 psi. Is there a specific reason for the he 85 psi?
07-17-2019, 08:35 AM
The Rotax maintenance manual calls out 6 bar or 87 PSI. Since the gauge is easier to set for 85, that's what I use. At 450 hours, we have yet to see a detectable drop in pressure... all four are 85/85.
Dale
Omaha, NE
Previous RV-7 project (sold)
07-18-2019, 01:33 PM
You need to read the Rotax manual before attempting. Also, you need the specific compression tester for Rotax. Not one for antique engines. The orifice size is different. A Rotax 9xx should loose little compression through out its life, if cared for correctly.
07-18-2019, 02:03 PM
The orifice specified for the tester for a Rotax 912 is .040. That is the same diameter that is used for a Lycoming.
Scott McDaniels
Hubbard, Oregon
07-18-2019, 02:17 PM
Correct. The aviation specific testers I looked at needed only the correct spark plug adapter.
And in case you're in the mood to save a little money... I looked at numerous similar compression testes intended for automotive use. All look and work the same, but the automotive testers are a fraction of the cost of course. Unfortunately not a single one of them has any detail about the orifice. When I asked, without exception they either simply didn't know or were unwilling to say what it was. I bought one from an aviation supplier.
Dale
Omaha, NE
07-18-2019, 02:46 PM
We made our own by breaking apart a used spark plug and welding an air fitting onto it.
Scott McDaniels
Hubbard, Oregon
07-18-2019, 03:19 PM
So did a friend of mine, My welding skills are insufficient.
Dale
Omaha, NE
07-19-2019, 02:19 AM
no welding equipment here, but bought the 14mm adapter from ACS (12-01283), available from other vendors as well
Life's short... Enjoy
DC aka Dan
http://www.aerofun.ch
