Old 07-17-2019, 07:55 AM
Ted RV8 Ted RV8 is offline
Default Rotax Compression Check
Don?t own a Rotax but curious.
Noticed a post calling out compressions of 82/85 etc. on a 100 hp Rotax. Question is are Rotax compression checks done at 85 psi? Most other aviation engines are 80 psi. Is there a specific reason for the he 85 psi?
Old 07-17-2019, 08:35 AM
DaleB's Avatar
DaleB DaleB is offline
The Rotax maintenance manual calls out 6 bar or 87 PSI. Since the gauge is easier to set for 85, that's what I use. At 450 hours, we have yet to see a detectable drop in pressure... all four are 85/85.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 07-18-2019, 01:33 PM
N456TS N456TS is offline
You need to read the Rotax manual before attempting. Also, you need the specific compression tester for Rotax. Not one for antique engines. The orifice size is different. A Rotax 9xx should loose little compression through out its life, if cared for correctly.
Old 07-18-2019, 02:03 PM
rvbuilder2002's Avatar
The orifice specified for the tester for a Rotax 912 is .040. That is the same diameter that is used for a Lycoming.
Scott McDaniels
Hubbard, Oregon
Old 07-18-2019, 02:17 PM
DaleB's Avatar
Correct. The aviation specific testers I looked at needed only the correct spark plug adapter.
And in case you're in the mood to save a little money... I looked at numerous similar compression testes intended for automotive use. All look and work the same, but the automotive testers are a fraction of the cost of course. Unfortunately not a single one of them has any detail about the orifice. When I asked, without exception they either simply didn't know or were unwilling to say what it was. I bought one from an aviation supplier.
Dale
Omaha, NE
Old 07-18-2019, 02:46 PM
We made our own by breaking apart a used spark plug and welding an air fitting onto it.
Scott McDaniels
Hubbard, Oregon
Old 07-18-2019, 03:19 PM
DaleB's Avatar
So did a friend of mine, My welding skills are insufficient.
Dale
Omaha, NE
Old 07-19-2019, 02:19 AM
DeeCee 57's Avatar
DeeCee 57 DeeCee 57 is offline
no welding equipment here, but bought the 14mm adapter from ACS (12-01283), available from other vendors as well
Life's short... Enjoy
DC aka Dan
http://www.aerofun.ch
