  #41
Old 07-11-2019, 09:48 PM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Originally Posted by s11033 View Post
On another front, how difficult would it be for someone like me to install an SDS EM5 kit assuming I was rebuilding my own engine?
Thanks!
If you're wrenching on helicopters, you won't have much problem installing an EM-5 or EM-6. Pretty much a bolt on and some power and ground connections.
Maybe a turbo to go along with that to make things interesting... Get 540 performance with a 360.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, Shorai- RV6A C-GVZX flying from CYBW since 2003- 441.0 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi2.htm
Old 07-11-2019, 10:01 PM
Toobuilder's Avatar
The SDS EFI solution is not an issue. Arguably it's no more complex than a typical FI system, just "different". If you can read Sikorsky tech pubs, you can install SDS EFI.
Also, if you think you can hang a 540 on the nose and think you will be satisfied with the RV-8 cruise speed, try again. 4000 ft/min of climb is fun, but limiting yourself to only 200 knots in cruise gets old real fast. Trust me, I know!
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 07-13-2019, 02:23 AM
s11033 s11033 is offline
I like what I?m hearing!
I completely believe that. Unfortunately I don?t think I think I have the time or money to build a full Rocket. My proposed plan really relies on finding a well advanced RV8 wing and empennage, and hiring some help for the fuselage. I think the ideal outcome would be an F8 with an EFII O-360. I was just wondering about the O-540 because I seem to see a good number of them out there.
Separately, any input on what parts need to be yellow tagged? I assume crank case, driveshaft, camshaft, cylinders, connecting rods and pistons?
Old 07-13-2019, 06:37 AM
Toobuilder's Avatar
You might get lucky. A neighbor recently purchased a nicely done HR-2 project that was 99% knocked together (it was even painted) for about $10k, and combined that with a low time 540 from a ground damaged Aztec for $12k. Admittedly, you don't find deals like this advertised, but they do exist.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 07-13-2019, 11:18 PM
That?s unreal... I don?t feel that I have the level of connections that I?d need to find that kind of deal
Old 07-15-2019, 05:30 PM
Hey guys,
On the subject of timing my build/purchase, would it make sense for me to wait for what I believe is an impending market crash / recessionary environment? I guess what I’m really asking is whether economic macros affect prices of flying kitplanes, partially completed projects, engines, etc.
If I could just buy a flying rocket, that would be the ideal scenario. But I don’t think I could do that at current market prices. Not sure how much they can be expected to fluctuate with the broader economy.
Thanks!
Old 07-15-2019, 05:54 PM
Toobuilder's Avatar
This is, has been and looks to continue to be a "buyers market". This IS the crash you are looking for. Despite the high end dreamers you see on BS and TaP, Rockets are not mainstream and their "selling" prices reflect that. Squirrel away $100k and you will have a broad selection when the time comes.
Michael Robinson
______________
RV-8 - SDS CPI
1984 L39C
Old 07-15-2019, 10:27 PM
Got it, thanks a lot. I haven?t kept up with the market at all.
I?ll have to price that against building a super F8 or a full on F1. I keep coming across cheap IO-540s that make me salivate...
Steve
Old 07-16-2019, 03:47 AM
Default Wisdom
?...if it seems too good to be true, it probably is...?
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 07-16-2019, 05:25 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Default Engines
Don?t limit yourself to the 540 - the 550N can also be used. 310HP out of the box, and very smooth with better fuel specifics.
Best,
Mark
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
