Old 06-30-2019, 05:58 PM
thompsonbr87's Avatar
thompsonbr87 thompsonbr87 is offline
Default GPS antenna under cowling
For those who have mounted GPS antennas under the cowl, can you share some pics? Did you build a shelf on the firewall? Engine mounts?
Barrett
Smyrna, TN - KMQY
RV-6A
Learning something knew everyday.
Donated dollars - 2020
Old 06-30-2019, 06:04 PM
ALagonia ALagonia is offline
Don?t know how to do pics but yes, mounted a shelf on the firewall for my GPS antenna for the GDL-82. Works flawlessly. If you send me an email address I can send pics that way
Old 06-30-2019, 06:28 PM
ArlingtonRV ArlingtonRV is online now
I did it on my -8. I used the F-01201R-1 shelf for the RV-12.
Steve Rush
Arlington, WA
ArlingtonRV on YouTube
RV-8 (Bought Flying)
Glasair Sportsman (Sold)
RV-8 Tail, QB Fuselage (Sold)
RV-4 (Bought Flying) (Sold)
RV-9 Tail
RV-12 120018 Flying (Sold)
RV-7 Tail, Wings, Started Fuse (Sold)
Old 07-01-2019, 03:35 PM
Onewinglo's Avatar
Onewinglo Onewinglo is offline
Default Engine Mount Shelf
We made a little shelf attached to the engine mount.
https://photos.app.goo.gl/UjDr2JR13PRWithy7
JP White
RV-8 "EL CABALLITO"
Cessna 170A SOLD
2020 Dues Gladly Paid
A new pilot having fun!
Old 07-01-2019, 03:45 PM
sglynn's Avatar
sglynn sglynn is offline
Default GPS antenna
I put both Dynon and Garmin antennas under the cowl. I've got 26 hours flying and both working just fine. You can see it here. Note my shelf is removable.
http://www.mykitlog.com/users/displa...=255575&row=22
Steve Lynn
RV-7A
Flying Phase I
Anacortes, WA
www.mykitlog.com/sglynn
Old 07-01-2019, 05:03 PM
Mark Dickens's Avatar
Mark Dickens Mark Dickens is offline
Here's mine:
Dynon and Garmin antennas mounted side by side. The Dynon antenna is less robust than the Garmin when it's hot under the cowl. It takes a few minutes to cool it off after a restart. The Garmin, so far, has been rock solid.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 07-01-2019, 05:37 PM
VNS VNS is offline
Default Option
http://s649.photobucket.com/user/psc...tml?sort=3&o=0
Patrick ZK VNS
RV 9A
Old 07-01-2019, 06:14 PM
Walt's Avatar
Walt Walt is offline
In case anyone cares, I will not to mount any IFR navigator GPS antenna under the cowl, bad environment for a critical device.
Personally I'll take function over looks any day of the week, but that's just me.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 07-01-2019, 09:16 PM
RVbySDI's Avatar
RVbySDI RVbySDI is offline
Hey Walt, I care. And I will agree with you. A delicate electronic device should not live in a hot dirty environment.
RVBYSDI
Steve
RV9A
https://rvwings.com
Live Long And Prosper! 🖖🏻
Old 07-01-2019, 09:59 PM
Gusmax Gusmax is offline
GPS antenna's under the glass cowl have been working great for many proven years. If your cowl was painted with a highly metallic paint (fine aluminum powder), it might effect performance??
Phil Kite
F4 Raider project with RV-8 wings and tail
