Old 06-26-2019, 04:24 PM
WingnutWick's Avatar
WingnutWick WingnutWick is offline
Default Spinning the 8
Has anyone done it? Characteristics? Recovery?
Thanks!
-Wingnut
Rhino driver by trade
RV-8 O-360
Old 06-26-2019, 04:36 PM
rwthompson67's Avatar
rwthompson67 rwthompson67 is online now
https://www.youtube.com/watch?v=tmfhsv-pRxY&t=1s
________________________________
Rick Thompson
RV-8A N306R #82456 Bought/Sold
RV-14 N327RT #140347 Slow Built/Flying
TBolt IO-390, Dual PMAGS, Hartzell composite, Dual HDX, GTN-650
Phase 1 Complete 4/17/2019
Old 06-26-2019, 05:15 PM
smithflys23 smithflys23 is offline
In my experience, the 8 easily recovers from intentional spins. Throttle idle, neutralize the ailerons, apply opposite rudder, then forward elevator. Easy!
As a heads up, If you let if go past 2 rotations, it will really wrap up!
Old 06-26-2019, 05:41 PM
sailvi767 sailvi767 is offline
Probably not applicable to the eight but I have found the F1 Rocket will recover itself as soon as you neutralize the controls after spin entry. I can?t even get to the point of applying opposite rudder. This is solo with the CG near the forward limit. I am interested if anyone has spun the F1 with the CG closer to the aft limit.
G
Old 06-26-2019, 06:30 PM
vlittle's Avatar
vlittle vlittle is offline
G
The Harmon Rocket, with the RV-4 tail needs positive recovery techniques... full opposite rudder and down elevator. Inverted spins need more chutzpah, which is in short supply. I wouldn't spin with rear CG because that implies a passenger.
V
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 06-26-2019, 06:37 PM
Mark Albery's Avatar
Mark Albery Mark Albery is offline
http://www.vansairforce.com/communit...d.php?t=113185
Old 06-26-2019, 07:17 PM
Robin8er Robin8er is offline
I've done a few spins in my 8. Standard recovery procedures, nothing out of the ordinary for spins. It does exactly what its supposed to.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 06-27-2019, 05:34 AM
Capt Capt is offline
I find my 8 very docile in a spin entry/recovery with one up and a fwd CG. I can just neutralise the controls and it stops itself fairly quickly, quicker with Std spin recovering though. Pretty benign planes the Vans if flown within their capabilities.
Old 06-28-2019, 04:57 AM
spatsch spatsch is offline
It spins like a good airplane should! Very typical spin behavior with no bad characteristics I was able to trigger ( and I tried .... ). Any of the couple of typical recovery techniques works for me. Neutral stick, forward stick, opposite rudder, neutral rudder take you hands of the controls. Some take longer to recover then others but with some patience they all get me out of it.
If you do lots of spins (50 turn is my max so far) the engine will eventually quit ( after 10 turns or so ) and the prop will stop unless you have inverted fuel due to centrifugal force on the fuel. No big deal will start right back up after recovery.
Be safe and have fun!
Oliver
Oliver Spatscheck
RV-8
N-2EQ
http://www.spatscheck.com/oliver
Old 06-28-2019, 05:03 AM
Default 50!?
A 50 turn spin? From what altitude?
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
