Old 06-25-2019, 01:49 PM
Christopher Murphy Christopher Murphy is offline
Default New hinge on horizontal cowl line
I need to replace/ repair the hinges on the horizontal joint on my Rv4 cowl. Has anyone used extruded hinge? AD rivets versus the crappy cs-4 pop rivets.
Cm
RV-4 "Mr. Twister"
Pitts S1S "Mexican Red" sold and missed
Mr. Twister Airshows
Rocky Mountain Renegades
the mission... have fun.
Old 06-25-2019, 01:51 PM
fl-mike's Avatar
fl-mike fl-mike is offline
yes to both, and AD is the standard for all newer kits. Don't recall CS-4 on the old 4 plans either, but it's been a long time!
Mike W
Venice, FL
N164WM
Old 06-25-2019, 02:33 PM
Default it was
It was some kind of cheap pull rivet.. they said not to use AD rivets. It was a long time ago.
Thanks for the info
cm
RV-4 "Mr. Twister"
Old 06-25-2019, 02:42 PM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Along the lines of a really long time ago...
I think that I used AD rivets but I squeezed them. And at the ends of the hinges, I used #4 screws for extra strength. Then I covered the rivet head with flox and very light, hobby store fiberglass cloth.
That was like 30 years ago, so who knows what I really did.
Ed
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 06-25-2019, 04:16 PM
If it has been drilled out to 1/8" for cs4-4 rivets, you probably wont be able to use AD rivets. I dont think you will be able to set a -4AD rivet without deforming the hinge. I would consider bonding the hinge and using -4 'A' rivets or bond and use a better blind rivet.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 06-26-2019, 04:38 AM
fixnflyguy fixnflyguy is offline
Default AD's and Proseal
I squeezed mine using AD's and also Proseal as a bonding agent. No loose rivets or issues in 300 plus hrs. The extruded hinge is superior to the formed, although I used the kit supplied formed hinge on mine. The key i believe is making sure the hinge pins are curved to match the curve of the cowling so there isn't constant pressure/rubbing. I keep mine clean and lube with a parafin wax stick that doesn't hold dirt and dust.
Bill E.
RV-4/N76WE
8A7 / Advance NC
