Old 06-18-2019, 03:36 PM
Gusmax Gusmax is offline
I just ordered an ELT tester that tests the ELT's for their yearly re-certification. The owner of the company I bought the tester from told me not to be surprised if the ACK units like your fail the test. He claims many or most ACK 406 ELT's fail.
Phil Kite
F4 Raider project with RV-8 wings and tail
Old 06-19-2019, 06:02 AM
FredMagare FredMagare is offline
Please provide an update when you resolve the problem. I'm seeing a similar issue with my ELT install. A check of the pins shows correct wiring/soldering.
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
RV-9A Firewall Forward
[Engine purchased]
Old 06-19-2019, 06:44 AM
Flying Canuck Flying Canuck is offline
ACK got back to me with this
Plug the remote directly into the ELT cable if it works it is the cable or audio alert unit.
That's all they wrote. I guess it's worth trying, I could even plug it into the first cord coming out of the ELT and bypass the extension cord they supply. I'll test this tonight and post my results.
Claude Pitre
RV-9A #91081, C-GCPT
Dynon SkyView HDX, IO-320 and WW 200RV C/S. Flying as of August 6, 2018
Interactive map of all of my flights here
Old 06-19-2019, 07:17 AM
Hi Claude,
My new ELT tester will hopefully show up by the end of the week. If you are bored and looking for an excuse to fly somewhere, you could fly up to EE6 and we to hook yours up to the tester and see if it passes or fails? I always enjoy seeing RV's here!!
Phil Kite
Old 06-19-2019, 07:46 AM
daddyman's Avatar
daddyman daddyman is offline
Default Coincidence???
Originally Posted by Flying Canuck View Post
I'm just wrapping up my first annual and tried the ELT test yesterday. I have an ACK E-04 121.5/406MHz ELT that is about 3 years old (battery good to 2021). I installed the batteries in the audio module and the remote in January 2017, those batteries expire in March 2024. The ELT was initially armed about this time last year. I cannot recall if I tested it back then and don't have my log books nearby. Anyways, back to this test. I pressed the test/reset button and nothing happens at all. I tried again after checking the main unit behind my baggage wall. Still nothing. I checked all of the phone cord connections from the ELT to the audio module and then to the remote. I'm going to pick up a new battery for the remote and try that, but does anyone have any ideas on what could make the simple test fail? I can try turning the ELT on from the main unit while my baggage wall is down, but haven't done that yet.
Pierre,
Strangely, I did the exact same thing within the past 48 hrs.
I also changed both batteries (front and in the rear by the unit), re-did the telephone wire and it worked.
Daddyman
Old 06-19-2019, 08:49 AM
Originally Posted by Gusmax View Post
Hi Claude,
Interesting proposition Phil. What does that hook up to? And how's the grass at EE6? I haven't done a grass field landing before and my first will need to be in great shape. Of course the rain is going to have to let up.
I'm planning a big trip to the east coast, leaving here on the 29th weather permitting. I would like a shorter cross country warmup, especially after my annual.
Claude Pitre
Old 06-19-2019, 11:21 AM
Moshonsk Moshonsk is offline
i had the same issues with my remote/switch until i looked closely at the 'phone' cable supplied with the unit. It is not a standard phone cable! Standard phone cables have the wires on the opposite ends of the cords reversed - ie. Brown/Red/Green/Yellow at one end and Yellow/Green/Red/Brown at the other. The cable supplied with the unit has the same pinout colours at either end and are not crossed. Once I made proper cables the same way everything worked just fine. You can also purchase a crossover coupling if you use a standard phone cable to reverse the pins back before they connect with the unit. i ended up doing this with the cable from the audio unit back to the ELT in the rear. Needed a coupling anyway back here to connect the extension with the unit so i just had to use a crossover unit instead of a standard coupling. If you do use a standard phone cable just make sure it has wires connected to all four pins as some cables are intended for single line jacks and only have the middle two pins wired.
Old 06-19-2019, 01:48 PM
RV7A Flyer's Avatar
And all of this sort of begs the question...*telephone cord*? (Or telephone-cord-like stuff)? In an aircraft? What the...?
Yeah, I have an Ameriking, uses the same stuff, but I just shake my head at this...to me, it's up there with using RG-54 TV cable for coax. Yeah, it'll work, but it just ain't right.
2019 Dues paid!
Old 06-19-2019, 04:05 PM
edameyer edameyer is offline
I had the same problem about a year ago. The audio alert unit was bad. I went around it as they suggested to you to isolate the problem. They quickly sent a new alert unit which solved it.
Old 06-19-2019, 05:19 PM
Claude, please PM for more details
Phil Kite
