Old 06-18-2019, 08:16 AM
greghughespdx's Avatar
Default New optional plans OP-58 - Lower cowl louvers for RV-6/7/9
Van's has published OP-58, an optional (OP) plan set which describes the installation of lower-cowl louvers in the RV-6/6A. RV-7/7A and RV-9/9A engine cowls (note: this kit does not fit other model cowls). The louvers may be used where additional exit air flow, such as for cooling purposes, is desired.
You can order kit "COWL LOUVER KIT" from the Van's Aircraft online store or by calling the Van's order desk. Cost for the kit is $8.00 plus shipping and it includes parts for creating louvers on both sides of the lower cowl. Complete instructions describing cowl modifications and installation of the aluminum parts included in this kit are found in the OP-58 document. The builder/installer will need to modify the lower cowl and will supply fiberglass fabric and other materials used during installation.
You may download the OP-58 plans/assembly instructions at this link.
greg
Building RV-8A since Sept 2014 (N88VX reserved)
Aurora, OR (EAA Chapter 105)
Old 06-18-2019, 11:57 PM
Arie's Avatar
Arie Arie is offline
Default Louvers
I think this is a great option. Any idea how much CHT will drop?
Interesting that the louvers bend inwards ( inside of the cowl) iso outwards. What would be the reason for that?
Old 06-19-2019, 05:46 AM
scard's Avatar
scard scard is online now
Wow. There is a welcome underlying shift in messaging with this addition.
Scott Card
CMW E-Lift
Old 06-19-2019, 07:22 AM
airguy's Avatar
airguy airguy is offline
Agreed. Instead of "you're doing it wrong" now we are getting "here is how to do it better, since you're going to do it anyway."
Old 06-19-2019, 07:40 AM
bcondrey bcondrey is offline
This is essentially how it?s done with the stock RV-10 cowl.
Bob
RV-10 builder x2
RV-7A under construction
EAA Tech Counselor
Old 06-19-2019, 08:18 AM
engineerorange engineerorange is offline
Default Test results
Now somebody hurry up and do a good job testing this new "option" for effectiveness in lowering CHTs and speed penalty after installation.
mangling aluminum since May 2009
RV7-A, flying
RV8 under construction
Old 06-19-2019, 08:26 AM
rvbuilder2002's Avatar
Since in all instances where the owner was asking for help in improving cooling, I have never inspected an RV that didn't have at least some level of issue with the baffling / cowling installation, and most of the time it was more than just minor leakage (Even though they were sure that it was as good as it could be), so this shouldn't be considered a Van's endorsed method of resolving cooling issues.
This is for instances where the rest of the cowl/plenum system has been optimized but other factors make adding additional cooling flow path area, beneficial.
Scott McDaniels
Hubbard, Oregon
Old 06-19-2019, 08:34 AM
vfrazier's Avatar
vfrazier vfrazier is offline
about 30 degrees CHT difference on N540VF, IO-540 F1 Rocket on hot days.
It's easy to install an inside track(s) to hold an aluminum sheet to block these off in the Winter.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 06-19-2019, 09:13 AM
DanH's Avatar
DanH DanH is offline
Same here.
Scott, curiosity questions please. Assuming our intrepid owner is forced to fly with crappy baffling and too much timing advance...
(1) Why not just remove the core, make the 4 ply 9-oz layup, and cut the slots, skipping the metal louver?
(2) Or, why not enlarge the standard exit? A simple 45 degree cut increases exit area by 41%. Costs nothing and can be done in 15 minutes.
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-19-2019, 10:39 AM
toc pilot toc pilot is offline
Default Louvers
I installed louvers during my build. I found them to be very effective in keeping the CHTs and oil temperatures in check during the summer months here in Arizona.
https://www.facebook.com/18143611188...type=3&theater
Bill Hempel
RV-7: N17HB AEIO-390, Hartzell Composite C/S prop, Dual Skyview D1000. First Flight: Oct 2017. 2019 dues paid.
https://www.facebook.com/Bill-Hempel...?ref=bookmarks
