Old 06-15-2019, 08:21 PM
Hornet2008 Hornet2008 is offline
Default Cold Starts without pre-heat
Hi All. We are experiencing winter in Australia while the lucky people in the north have warmer climes. Gets sub zero here, we measure temperature in Celsius. Reading Mike Busch's book on Engines he states you should never start a Lycoming below 32 degrees F. I have my Dynon EMS set up in degrees F and don't start unless temp is at least 40 degrees F. What I am finding is the oil pressure is agonisingly slow to come up. Takes about 30 sec to 40psi. Newish engine, 41 hours, Shell straight 100 oil.
Is this going to harm the engine?
Pete
RV-9 "Cloud tinnie"
Registered VH-EAB
Flying Phase 2
Old 06-15-2019, 09:08 PM
Plummit's Avatar
Plummit Plummit is offline
Depends.... ;-) How long since the last run? I feel that's more important to preventing engine wear, but it sure wouldn't hurt to have it a little warmer, even with a simple light bulb and some cowl wraps.
-Marc
RV-10
N814RV
2020 Donation Made
Old 06-15-2019, 09:18 PM
lr172 lr172 is offline
100 weight oil is TOO thick for operations in freezing temps. Recommend 20W50 or at least a straight 80 weight. You want the oil to flow well at startup and that 100 weight is like honey at 0 F.
I preheat, via a sump heater, when ambients are below 40* F The colder the temps, the harder the start is on the cylinders. That said, many engines are started without pre-heat in the winter and make it to TBO. IMO it is harder on the cylinders during a startup on warm cylinders that have sat for a month than a cold start on cylinders that have sat 3 days. Cold startings biggest issue is piston wall scuffing which has a very minimal long term effect on a cylinders longevity.
Larry
Old 06-15-2019, 09:59 PM
Generally I fly a couple of times a week, sometimes a week between starts. Don?t always get sub zero temps, try to avoid them but did start this morning at 42 degrees F. Take point on oil and noticed at the oil check it was pretty thick. Not sure what to do with a light globe/bulb.
Pete
RV-9 "Cloud tinnie"
Registered VH-EAB
Flying Phase 2
Old 06-15-2019, 10:04 PM
DanH's Avatar
DanH DanH is online now
Absolutely. Switch to a multigrade. Much lower viscosity when cold, same viscosity when hot.
Dan Horton
RV-8 SS
Barrett IO-390
Old 06-16-2019, 05:33 AM
sailvi767 sailvi767 is offline
Switch to a multi grade ASAP. We always use 20-50 in the winter with temps like yours.
Old 06-16-2019, 06:05 AM
FLY6 FLY6 is offline
Default Light
The lightbulb is placed under the cowl. It must be an incandescent type or something else that gives off a lot of heat. Put blankets etc. around your cowl and plug your cowl openings. Allow this to heat the engine for some time. If you have a small micro heater you can also direct the hot air into the cylinders. If you do a search here on the forum, I?m sure you will find lots of remedies that people use. If you get enough cold weather often, you can buy an engine heater that sticks on you oil sump. With that turned on for a few hours, it will preheat your whole engine.
Al Grant
Flying RV6, O-320, 160hp
Burlington, On
Dues Paid
Old 06-16-2019, 06:41 AM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
Default My winter drip...
Phillips XC 20-50
Reiff sump heater: https://www.reiffpreheat.com/
Switchbox control, to remotely start the Reiff heater the night before I fly: https://switchboxcontrol.com/the-switch-box
A mover’s blanket pad draped over the cowling to hold in this heat during preheat.
Scroll
Catch her on YouTube's "Because I Fly!" channel
Exemption waived.
Proud and grateful 2020 -=VAF=- Contributor
Old 06-16-2019, 07:39 AM
SmilingJack's Avatar
I did what Sid outlines.
I also though I saw a picture of a ruptured oil cooler somewhere that sold me on the sump heater.
I also added the cylinder band heaters and a thermostat that I placed inside the cowling.
Of course, this was when i lived in upstate NY...now...well...my enigine never sees less than 80 degrees
John Mastro
RV-8
Old 06-16-2019, 08:53 AM
pilotkms's Avatar
pilotkms pilotkms is offline
Default Heat Gun
All great ideas. For my 6 flying days this past year when the temp was below 40, I put my $10 heat gun in to the cowl exit 1 hour before start up. Raised the oil temp to 50+. Using 15W-50 also.
Keith
RV 7A RV #9700 May 2017
N325KS the Flying “K”
Built in SoCal KCCB, now in GA @ KPXE
550+ Hours & 7X cross the USA
OSH flyin 2018 & 2019 & Petit Jean 2019
