Old 06-03-2019, 08:27 AM
1bigdog 1bigdog is offline
Default z-bar extrusion
Hi All
Does anyone have a source for aluminum z-bar extrusion in the greater Toronto Area. Appears AC Spruce does not carry this. I'm looking for 1/2" height.
Thanks.
Michael B.
C-FWMB (reserved)
College Fund Contributor
Old 06-03-2019, 08:49 AM
Default mcmaster
Not in Toronto but Mcmaster has it:
https://www.mcmaster.com/aluminum-z-bars
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 06-03-2019, 12:22 PM
Default thanks.
My only concern with what I see on McMaster is the absence of an inside radius.
But appreciate the lead.
Michael B.
C-FWMB (reserved)
Old 06-03-2019, 02:00 PM
Default or...
Try here:
http://www.americanaluminum.com/stan...trusion/z-bar/
Bob
RV-10
297 HP Barrett Hung
Wiring...
Old 06-03-2019, 03:07 PM
PhatRV PhatRV is online now
Do NOT order from McMaster. They don't carry the aerospace grade Z-section, which has the large inner radius for stress relieving. The McMaster aluminum has sharp inner corners which cannot be used on our airplane.
RV8 standard build: Empennage 99% completed
Wing -- Closed
Fuselage -- Canopy Started
Avionics Installation -- Bench tested
Firewall Forward -- New engine received !
Electrical -- After engine installation
Donation paid through 2020
Old 06-03-2019, 04:39 PM
Default Disagree
I would disagree with your premise that the mcmaster z channel cannot be used in our aircraft. That would be entirely dependent on the particular application, and there are places where ?non aerospace? materials can safely be used in an experimental aircraft.
That being said, the OP did not indicate a specific application or structural loading...
Bob
RV-10
297 HP Barrett Hung
Wiring...
Old 06-04-2019, 08:51 AM
Default for the console quad
Hi Gents
To be clear on 2 points, I have made an effort to stick with aviation grade on everything. And the specific application in this case is for the side offset of the throttle quad on the centre console I'm building.
The inner radius is required from my perspective because the forces in most cases may be mild but can be significant during turbulance when holding the throttle. I'm also looking at the occasional unintentional forces or impact during entry and exit. There will be forces in all directions. At the moment we are looking to press the angles in on an 063 plate. The z-bar would have been much more simple but we just got access to a quality press/brake yesterday afternoon. As a single plate to support all 4 bolts of the quad we get a lot more stability than the z-bars but it is now a fallback position.
Thanks.
Michael B.
C-FWMB (reserved)
