06-01-2019, 03:39 PM
Carburetor Rebuild Shop
Was looking through the archives for a carburetor rebuild shop but all of the posts seem dated.
I am in need of a rebuild/overhaul for my MA-4SPA, and I am looking for a recommendation.
Local to the PNW would be even better.
I'm not opposed to just swapping it out but mine has an over-sized jet that Ly-Con fitted to my carb during the engine runs on the test stand,, way back when,, and I don't want to lose it.
Thanks in advance!
Derrick L. Aubuchon
RV4 (Flying, approx 900hrs)
Tacoma Narrows Airport (TIW)
dlaubuchon@gmail.com
( 2020 dues paid)
06-01-2019, 04:36 PM
D&G Supply
Look up D&G Supply online. They just did two for me and did a fantastic job. I took pictures of the carb before I sent it in and could not believe it was the same one I got back. It was perfect.
Anthony
RV6-A "Aluminum Mistress"
Too many hobbies- not enough time.
2016, 2017, 2018, 2019 donor and happy to do it.
06-01-2019, 05:59 PM
Just out of curiosity what's a typical rebuild cost? I'm in the same boat.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
06-01-2019, 06:38 PM
It was in the 800.00 range. Comes yellow tagged.
Anthony
06-01-2019, 08:10 PM
When I had mine overhauled I was told by several carb shops that only the factory was capable of flow testing. Mine ran about $880.00. You may want to consider changing out the aluminum fuel connection fitting. Also, it appears that the plug opposite the fuel inlet locking tabs are not bent over.
RV7A Completed
N315S
Dues Paid
06-01-2019, 08:17 PM
Just got a rebuilt MA3-SPA for my Cub from Spruce.Around $800 or so exchange. You can swap out what you need before you send the core back.
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 350+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600 QUICK Panel.
Manual Flaps. (KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis,floats.
2020 dues gladly paid.
06-01-2019, 08:26 PM
It is steel now and I caught the tabs not being bent. Good eye!!
Anthony
06-02-2019, 07:47 AM
Check these guys out in the DFW area. WWW.aircraftcarbs.com. Tel. (940)6482277. FAA approved repair station. I've had them do my MA3, Stearman carb, Christen Eagle fuel injection. Great work, reasonably priced.
06-02-2019, 09:52 AM
Most of us at 52F use the same guy Steve just mentioned. Dave does great work.
46 Luscombe 8a Rag Wing, Armstrong starter
RV-6, IO-320, Catto, G3X Panel (Thanks Walt!)
