Old 05-25-2019, 04:41 PM
Walt's Avatar
Walt Walt is offline
Default Fire in the hole...
Actually in the airbox, vertical induction FI with no drain holes for excess fuel to escape. I saw another similar situation that caused a lot more damage, this one escaped with some minor air cleaner and fiberglass damage.
Airbox's (both carb and FI) need drain holes, I put 3 in, one in front and one behind the air cleaner for rain and such and another in the center of the filter to drain excess fuel that may accumulate there (tail draggers get the hole towards the rear).
This one will get the standard metal plate in the bottom repair as the fiberglass is also worn thru in a couple spots.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 05-25-2019, 05:05 PM
lndwarrior lndwarrior is offline
And this exact scenario was described in Vic Syracuse's seminar which I just watched.
Old 05-25-2019, 05:39 PM
Kiwi flyer Kiwi flyer is offline
Walt, what gauge for the plate in bottom do you recommend, about to do this on the 10 model, thx Pete
RV10 Finishing kit done, Fwf complete, interior started. 2019 donation paid with thanks.
Old 05-25-2019, 06:06 PM
greghughespdx's Avatar
Ya beat me to it. Great presentation by Vic, for sure. A variety of other important things to watch out for in maintenance and inspections that he points out, and it's not only loose jam nuts!
Building RV-8A since Sept 2014 (N88VX reserved)
Aurora, OR (EAA Chapter 105)
Old 05-25-2019, 07:14 PM
Walt's Avatar
.032" works pretty good for the bottom plate.
Old 05-25-2019, 07:17 PM
And what size drain holes?
Dave
Do you bond it inside the airbox with proseal, or is there a better way?
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 05-25-2019, 07:28 PM
Walt's Avatar
Dave
#27 front and back, 1/8" in the center with a nice countersink
Yes I use proseal to bond it. It's captured by the filter so no real worry about it coming loose.
Old 05-26-2019, 08:02 AM
JonJay's Avatar
JonJay JonJay is offline
What caused the fire?
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-26-2019, 03:05 PM
scsmith scsmith is online now
This is what the sniffle valve is for in horizontal induction sumps.
I sometimes worry that for a taildragger, the sniffle valve is not quite in the best location. But it can not accumulate very much.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
