05-17-2019, 07:05 AM
Use the advanced search function and use my user name (N941WR). Some time back I posted all the firewall penetrations called out in the plans.
Some are best done early but don't show up in the plans until after the engine is hung
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
05-20-2019, 03:15 AM
Even if I was very confident I knew where to drill the holes without the final engine on I would only drill them as max #30 pilot holes. If when the engine is on they are indeed in the right place enlarge. If not it's only a #4 rivet to fill the hole rather than a patch. I still have holes to drill to locate some pass throughs and FW parts. The only holes I drilled before the engine was on was the holes to attach the engine mount itself. All my stainless holes start as #40 the pilot hole is the hardest to get through after that step drill and or final drill size easily enlarges the pilot when your certain. The side benefit is that you can use cleccos to easily hold components on to confirm any interferences. But lots of my stuff is non-standard/oddball FWF, (standard aviation) but so far off the Vans reservation no idea anymore what a standard Vans plans build is like following their instructions.
Regards,
Rob.
................__|__
......______(-o-)______
M: (61) 401 578 700
05-20-2019, 06:58 AM
Ryan, prior planning always helps. But those plans can change, and often do. Especially locations for accessories. Think about what you want--check the plans, and pics of others with similar equipment. Think some more, measure about 3 times. Prior planning certainly will save you a bunch of potential headaches later.
Tom
Ridgeland, SC
05-20-2019, 08:49 AM
Indeed! After drawing these items onto the firewall with a sharpie, it's obvious that there will be a conflict between the fuel line doubler and the starter solenoid's bracket:
I'll either move the fuel line hole down a hair or grind off the corner of the doubler. It doesn't look like this will make any difference whatsoever because there's a flexible hose on the engine side.
This exercise has convinced me not to drill anything until I at least have all the things that attach to the firewall in my possession. I'll also be sketching out Vans entire plan onto the firewall as a way to familiarize myself with what's on this side earlier and plan ahead.
And, related to planning ahead: Not sure how I'm going to dimple the new hole that's needed for nutplate that the starter solenoid's bolt goes through. The firewall is already riveted to the vertical stiffener angle. I may just have to end up countersinking through the thin firewall.
Ryan Drake
Livermore, CA
https://stiletto.smugmug.com/RV7
Donated 12/16/2019
RV-7A (N12VD): Empennage and wing kits complete minus fiberglass, fuselage and wiring complete. Canopy complete minus fiberglass. Waiting for the engine to come!
05-20-2019, 10:17 AM
There are a couple options for dimpling those types of holes. One is to countersink a metal block, place the block on the back side and use a rivet and rivet gun to do the work. Another is a kit you can purchase with small dies and a nail that you pull with a hand squeezer rivet gun.
For what its worth, I did not rivet the backing plate for the master and starter relays. The bolts hold it in place just fine.
My fuel line is much lower than the plans; maybe 3 inches above the lower side of the FW.
Ray
05-20-2019, 10:31 AM
Ray, I'm not too worried about dimpling through only the firewall--I do have tools for that. What I'm puzzled about is dimpling the firewall where there is already an aluminum stiffener behind it. Normally I'd countersink the stiffener, and then dimple the sheet, but in this case, the stiffener has long ago been riveted to the sheet!
Ryan Drake
Livermore, CA
Donated 12/16/2019
05-20-2019, 01:55 PM
Ryan,
I sent you an email with an earlier pic which shows the situation before I resolved it.
Ray Tonks
2020 Donation Paid
Titan IOX-370, Dual PMAGs, 9.6:1 Pistons, FM-150
RV-7 Fuselage in progress
* Cabin Interior - In progress
RV-7 SB Wings
* Both Wings fully skinned
* Fuel Tanks Complete - No leaks finally
* Ailerons Complete
* Flaps Complete
RV-7 Empennage - Complete (a little fiberglass work left)
Vans Training Kit # 2 - Complete
RV-7 Preview Plans
Vans Training Kit #1 - Complete
EAA Sheet Metal Class - Complete
05-21-2019, 05:45 AM
If you re-use an existing rivet hole, that should be covered. I don't recall having to install/countersink any other holes in the FW where a stiffener backed the hole.
Ray
05-22-2019, 09:38 PM
Watching thread with interest as I'm just starting the fuselage slow build and working on the firewall. Seems like a lot other steps could/should be done while it's easy to work on the SS including:
1.) Fuel line doubler for the I/O 360, others say no and wait... seems like that should be a very well known placement? (DWG OP32)
2.) Dimple upper holes now for the F-1107 L&R, why not?
3.) Battery mount holes, why rivet to only drill out later? Order battery box now or wait?
4.) Master relay and starter solenoid, drill now? and fab doubler? Seems like I should order these now?
5.) Holes for brake reservoir?
Thoughts on these?
05-22-2019, 11:07 PM
Battery box
The only thing i did on my firewall during initial build was add the Vans battery box for the odyssey battery and drill the holes for the relays. I figure everything else can wait until i have the engine mounted. I will let you know how it turned out in a few years.
John S
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Electrical 5% in work
Firewall Forward 5% in work
