05-13-2019, 04:25 AM
Nippon Denso positive regulator
I took the alternator to a shop today and had it tested. It was OK but he had wanted to test it together with the regulator which I hadn't brought with me. I asked what kind of regulator I needed he said it had to be one with positive regulation since this is a Nippon Denso alternator. I have looked around on the internet but it doesn't really say if they are positive or negative. Can anyone recommend a suitable regulator for this alternator?
Hans Str?hle
Jodel sold (SE-XEV)
RV-4, flying any day (SE-XJJ)
F?rentuna, Stockholm
Sweden
EAA222
2020 =VAF= $20 donation paid
05-13-2019, 09:26 AM
If memory serves, most all US vehicles use positive field supply and MOST, but not all, European cars use a negative field supply, with the Asians split between the two.
If the alternator is spec'ed for a US vehicle, use a standard Ford regulator. ND alternators designed for US vehicles will be positive, eventhough ND is an Asian supplier.
Larry
05-13-2019, 04:30 PM
Yeah any VR-166 Ford clone will work with that alternator. Did on my ND I just tested.
05-13-2019, 07:36 PM
Ebay has them for about $20 with free shipping.
07-10-2019, 03:45 AM
Larry
I talked to an electrics guy and he said I needed a VR-0120 regulator so I bought one and the alternator gave over 16V and the fuse popped out. A club member suggested it might have an internal regulator and how should I know. How can one tell? It has three connections posts, E, F and N.
Hans Str?hle
Jodel sold (SE-XEV)
Sweden
EAA222
07-10-2019, 02:54 PM
An ND alternator with those three terminals should be externally regulated. What model # is it?
A quick search shows that VR is spec'ed for European cars and therefore likely a Neg Field control. Your symptoms would seem to suggest that as well. Possibly time to find a new source for recommendations.
Larry
08-09-2019, 10:52 AM
Solved
Larry
I got my VR-0120 correctly hooked up now and it is working fine.
Hans Str?hle
Jodel sold (SE-XEV)
Sweden
EAA222
