Go Back   VAF Forums > Model Specific > RV-6/6A
Old 05-12-2019, 11:34 PM
deene deene is offline
Default Cowl changes when going from FP to CS on a RV6
Vans mentions that changing from a FP to CS prop requires a different cowl (and spinner).
Anybody with direct experience on this change care to comment?
Deene Ogden.
N399AD RV-12...flying
N299AD RV8 QB, IO-390X, BA prop...SOLD
N199AD One Design...SOLD
N99AD BD4, flew for 22 years...SOLD
EAA Tech Counselor/Flight Advisor
CFII, MEI, CFIG
Old 05-13-2019, 05:10 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Set up
It must depend on the setup.
My hangarmate has a -6 that was originally built with a wooded FP prop with a 4" extension. He swapped to a CS hartzel and everything lined up perfect.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 05-13-2019, 05:32 AM
titanhank's Avatar
titanhank titanhank is offline
I completed this swap 10 hrs ago on my 0320 rv6. I have a fixed pitch cowling. I went from a catto 3 blade with a 4” spacer to a whirlwind rv200 with a 2” spacer for c/s props. The prop spinner to cowling gap is .43” vs the .25” that is in the plans. I have a conical mount and would get rubbing under high g loads. The .43” looks good and so far has not made contact with the cowling. I did have to cut the spinner hole out .5” all the way around to allow the tapered spinner backplate to fit.
You will be amazed at the performance difference. You won’t gain much top speed, but the takeoff acceleration and climb makes all the work worth the trouble and expense.
Rv-6
0-320/180+hp
10-1 pistons
Lycon port/polish
Dual pmags
EI Commander
Whirlwind 200rv prop
IFR Glass panel
Trutrak Vizion 385 Autopilot
Flightline Interior
Almost rv14 seat mod/cable locking
Electric seat back adjuster
Old 05-13-2019, 08:04 AM
Default Thanks
I?m helping a friend with the engine and prop upgrade and hope to not have redo the cowl.
The original setup had a 2 1/4? spacer with a Sensenich FP prop. After a prop strike, we are installing a new Lyc IO360 with a BA CS...
Deene Ogden.
CFII, MEI, CFIG
Old 05-13-2019, 09:59 AM
billnaz's Avatar
billnaz billnaz is offline
Default I'm going with the new cowl
I'm in the middle of upgrading from Sensenich FP to Hartzel CS. I had hoped to reuse spinner and cowl. Forum search shows entries stating you can add spacers to the engine mounts to add a little clearance. I found that was not going to provide enough space. With the CS prop I went from the appropriate space to zero clearance. Too much to correct with washers on the engine mount in my mind. On the plus side, the current offering from Vans for cowling (prepreg) is an order of magnitude better in quality than my original gelcoat cowl.
Bill Grischo, Gilbert AZ
N911WG RV-6A DVT
Flying, thinking about polishing
Old 05-13-2019, 11:08 AM
rvbuilder2002's Avatar
There are variables that must be considered when switching from a fixed pitch to constant speed prop.
It is primarily related to the vintage of cowl that was used when the airplane was built.
Early cowls were sized to use a 4" prop extension with a fixed pitch prop.
Later cowls that worked with a F.P. or constant speed prop used a 2.25" spacer with the fixed pitch or a standard compact hub constant speed.
If you have a cowl that was using a 4" extension with a fixed pitch prop, you will need to do one of three things
- install a newer version cowl
- Use an extended hub style Hartzell prop (generally not approved for aero)
- Use a compact style hub prop with a 1.75" spacer (I am not what options are available for this)
If you currently have a 2.25" spacer on a fixed pitch prop, you should be able top switch to constant speed with no cowl fitment issues.
Scott McDaniels
Hubbard, Oregon
Old 05-13-2019, 03:42 PM
We have the 2.25 spacer. Thanks for the help.
Deene Ogden.
CFII, MEI, CFIG
