05-10-2019, 09:03 AM
Aileron Rigging
Is there any way to check the aileron rigging without taking off the wingtips???
My ailerons are about a ?? lower than the flaps which are not fully flush either. It may be normal, but it doesn?t look right. The wingtip screws are painted on and I don't want to mess up the paint.
Mark K
N1075 RV9A
FLAPS Fully Retracted
[IMG]  [/IMG]
LEFT Aileron
[IMG]  [/IMG]
RIGHT Aileron
[IMG]  [/IMG]
Mark Klepper
N1075 FA81 - Ft Myers, Buckingham Field
Van's RV9A Slider
05-10-2019, 09:35 AM
Yes there is a way to rig without removing the wingtip
Mark,
I see the pictures of your aileron above. My questions would be how do they look in flight and does the plane fly level without trim?
You have two rod ends for each aileron (one at the aileron and one at the bellcrank in the wing). One full turn of a rod end is worth about 1/16” inch. I adjusted mine to trail with the flaps (at the inflight condition). Additionally, You can adjust them to counteract any heavy wing condition.
NOTE: be certain to comply with any minimum thread requirements as stated by Vans
Marvin McGraw, 5TN4
RV-14. #140039 Complete
Flight hours: 500+
2020 Dues Paid
The Dues Paid note is a reminder for me
05-10-2019, 09:36 AM
Flaps are generally in a "reflex" position, meaning they will be a little higher than the ailerons. I believe the goal is to have the flaps up against the rear spar so the flap mechanism is not under load during normal flight. Some prefer to make everything line up, but it is very build specific due to wing mount variations.
The tips should come off at each condition inspection, so the screws shouldn't be a concern. Replace with stainless, IMO.
Ray
05-10-2019, 09:47 AM
Make sure when you rig the ailerons, that the elevator is held or locked neutral.
05-10-2019, 10:24 AM
To the OP question, yes you can check aileron rigging without taking off the wingtips.
But, you have multiple issues to be checked and fixed. If you rely on the ?tooling holes? approach to rigging you can easily end up with rigging problems. I?ve seen a lot of RVs not properly rigged. Rigging is not ?one and done?.
Here is one of a few posts I made on rigging: http://www.vansairforce.com/communit...=165907&page=2
For builders not yet there, I again strongly recommend deferring wingtip fit-up until after the wings, flaps and ailerons are mounted and rigged.
Carl
05-10-2019, 10:49 AM
It looks like the flaps and the ailerons are mis-rigged, but there can be numerous other things that can cause mis-alignments between wing tips ailerons and flaps and fuselage. One major one is twists in the control surfaces. This can be checked for by measuring the angle of a surface at each end while holding it stationary. If they are not twisted, the measured angle should be the same at both ends.
Scott McDaniels
Hubbard, Oregon
05-10-2019, 02:28 PM
Originally Posted by M McGraw
Mark,
You have two rod ends for each aileron (one at the aileron and one at the bellcrank in the wing). One full turn of a rod end is worth about 1/16? inch. I adjusted mine to trail with the flaps (at the inflight condition). Additionally, You can adjust them to counteract any heavy wing condition.
The ailerons in flight are roughly the same as shown, both below the flaps in level flight. The aircraft does not exhibit any wing heavy condition.
I don't think one aileron being up or down would cause a wing heavy condition. A wing heavy condition would be caused and corrected by adjusting the flap trim.
What's got me started down this road, is I have a friend with another RV9A with same engine, and his aircraft is faster by 5-10 knots. That was confirmed by running both aircraft WOT side by side at multiple altitudes. (I know there are lots of things that could be causing the speed difference. The trim is what I'm focusing on now.)
Mark Klepper
Van's RV9A Slider
05-10-2019, 03:16 PM
I'm not surprised
As I mentioned it looks like your ailerons and flaps are both miss rigged. This wont necessarily cause a roll trim problem any more than flying around with your flaps partially deployed will.
But, if your ailerons and flaps are both drooped downward it will definitely cause drag and a loss of speed.
Scott McDaniels
Hubbard, Oregon
05-10-2019, 07:37 PM
I have rigged my ailerons with the tooling holes and bellcrank locking plate during initial rigging and checked at last condition inspection and still get a roll to the left in flight. Could I eliminate this roll by adjusting flaps? Thanks in advance.
Pete
RV-9 "Cloud tinnie"
Registered VH-EAB
Flying Phase 2
05-10-2019, 07:50 PM
A "heavy wing" is caused by the wings producing a different amount of lift on each side. YES, adjusting the flaps will correct this problem. A single turn of the turnbuckle results in a very noticeable change. My plane would bank and turn to the left with hands off. It took only a half turn to correct it.
Mark Klepper
Van's RV9A Slider
