Put a rivet at the intersection of the bulkhead and stringers. Then simply space your rivets so they miss the intersection when you add the skin on.
Along the longeron add rivets every 3 or 4 spaces in between the final skin rivets on the lower skin.
Make sure you place a straight edge alongside the bulkheads, the early plans had some errors in the bulkhead spacing.
That is how I did my -6A.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
