Old 04-29-2019, 07:16 PM
mbuehler mbuehler is offline
Default Disable traffic alerts GRT HX?
I've tried toggling off all settings related to traffic in setup, but I can't seem to disable the "BEEEEEEP TRAFFIC!!" alert or the depiction on the map. When I get into busy airspace (BFI, SEA, SFO) the alerts are constant and make radio communication difficult as it drowns out ATC. Additionally the map becomes a useless sea of black traffic "hits" and all airspace and everything else is covered.
I like the METARs, Radar and everything else ADSB provides, but traffic alerts are far more a distraction than a help. 40+ audible alerts and a blacked out screen every time I go to land at Boeing is really annoying.
Is there a setting I'm missing?
Martin Buehler
2004 RV4 N1080J
IO320 - CS - IFR
Old 04-29-2019, 10:40 PM
lr172 lr172 is offline
I believe there are filters for both altitude and distance proximity for generating an alert on the GRT.
Larry
Old 04-29-2019, 11:39 PM
Larry
+1. The filter limits are in the set up menu.
Old 04-30-2019, 12:18 AM
AX-O's Avatar
AX-O AX-O is offline
There is an altitude envelope and a radius. I set mine to +/- 3000 ft and 15 nm. anything outside that does not get displayed. you can restrict it more than that if you want.
Axel
RV-4 fastback thread and Pics
VAF 2020 paid VAF 704
Old 04-30-2019, 09:51 AM
tommylewis's Avatar
tommylewis tommylewis is offline
Default Traffic alert
If it is the audio traffic alert that is your problem, just remove the audio traffic message. I never installed traffic or obstacles audio alert on my GRT HX units.
Tom Lewis
RV7a N967BT 1900 hrs.
RV10 N143EB 960 hrs.
Granbury, Tx
http://bit.ly/2bnimsZ
Old 04-30-2019, 10:52 AM
dtw_rv6 dtw_rv6 is offline
I wish there was a suppression button for these alerts. Only way I’ve found to shut Betty up is to disable the serial port
I’m installing a toggle switch... yuck
Better is the enemy of good enough!
Don
Old 04-30-2019, 02:20 PM
I'll take one more look through the menus, I may have missed the filtering options. A suppress or inhibit button like the other alerts have would be great. If I'm on the ground trying to copy a clearance I don't care about traffic!
I removed all the wav files for alerts, but it seems traffic's is built in and doesn't work from the USB drive folder.
Interesting idea on the toggle, that might be the way to go. At BFI we are all under the bravo at ~1200' and just a few miles from SEA and RNT. Not sure there is a filter narrow enough to block that, just being able to disable it outright may be the ticket.
Thanks everybody!
Martin Buehler
2004 RV4 N1080J
IO320 - CS - IFR
Old 04-30-2019, 02:44 PM
Thanks everybody!
Play with the filters. Our airport is 8 miles from ORD and I have no real issues. Though I don't pick up an ADSb reception on the ground.
Larry
Old 04-30-2019, 07:25 PM
Adjust the volume of the traffic alerts so that you can hear them, but they're noticeably lower than your com radio. In the air, you'll hear them; on the ground copying clearances, your brain will ignore them.
Old 04-30-2019, 07:30 PM
Toggle or suppression is the only way for me. Try going for an hour flight with 4 other planes. No matter how quiet the volume is, the constant growl of ?Trrrrraaffic!? grates on my nerves.
Don
