Old 04-28-2019, 01:43 PM
sblack sblack is offline
Default Rotax maintenance costs
Friends with a 912 powered airplane were charged 40 hrs to have fuel and oil rubber hoses replaced buy a local rotax dealer. That seems outrageous to me, but I am not a rotax guy. Is this out of line?
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 04-28-2019, 04:43 PM
Cammie Patch Cammie Patch is offline
Depends.
My first big job as an LSRM was a rubber hose change on a CTSW. It took me five weeks! It was also an annual IIRC, and I wanted it to be perfect. I would spend all morning studying, then work on the plane in the afternoon. The engine had to be removed to get to the hoses.
Now I could probably do one in 4-5 days. I'm not fast, but I like to take my time and do it right. I probably would have a very small customer base if I did much work for the flying public.
But really, they are not required (the hose changes). I would recommend changing them on condition only. But, but sure to get a good look at them. I've seen quite a few fuel lines that are leaking, but leave no trace outside of the fire sleeve.
Old 04-28-2019, 05:06 PM
In this case the engine was removed and brought to the shop by the owner.
LSRM? CTSW?
Scott Black
VAF dues 2020
Old 04-28-2019, 05:44 PM
sf3543 sf3543 is offline
I just did the complete rubber replacement on my 912 including changing the oil and fuel lines and components.
Changing the coolant lines and refilling coolant took most of an eight hour day.
Changing the oil lines and purging the system, including verifying the lifters were charged, took a little less time to do.
Add about 3 or so hours for disassembly and reassembly, since removing the muffler and exhaust is necessary to make it easier.
For those two tasks, I?d say 40 hours is excessive.
In my opinion.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
Old 04-28-2019, 06:15 PM
AirHound AirHound is offline
In my opinion.
Did you go with Aircraft Specialty Teflon kits?
Old 04-28-2019, 06:34 PM
Yes
It was a perfect fit from them and their service on ordering was very good.
I would highly recommend them.
Steve Formhals
RV3B
RV8
Old 04-28-2019, 09:12 PM
Yes
I got?em 2 and other than water hoses no more gas or oil hose changes, yippee.
Also bought their oil pressure gage relocation hose kit. Mounted it on top of top radiator hose back near the firewall, rock solid indications, recommend it!
Old 04-29-2019, 10:56 AM
DaleB's Avatar
DaleB DaleB is offline
40 hours sounds like about what it would take someone who had never done it before, and lacked the tools needed, to do it on an engine still in the airplane. I cant imagine a qualified Rotax maintenance shop taking anywhere near that long. But that's just me.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 04-29-2019, 03:25 PM
PilotBrent PilotBrent is offline
In my opinion.
Similar experience. One full day for the coolant hoses, fuel lines about half that. I'm slow and careful...mostly slow. 40 hours does seem very excessive.
Brent Connelly
Hackettstown, NJ
RV-12, N913BC
http://www.mykitlog.com/brent45
Check out & subscribe to my Youtube channel for latest RV-12 flying videos...
https://www.youtube.com/channel/UCxQ...Px2I7jmazGdLqg
Old 04-29-2019, 06:31 PM
Thanks for the feedback guys.
Scott Black
VAF dues 2020
