Old 04-22-2019, 08:46 PM
Frankster13 Frankster13 is offline
Location: Sausalito CA in Northern CA near wine country
Default WAAS and Serious Satellite GPS Antenna Location
What is the consensus on mounting GPS antennas? I am somewhat reluctant to mount these two antennas on the top of the fuselage aft of canopy but I don't want to mess around and mount internally on a ledge under back canopy only to get lousy reception.
Thoughts?
Old 04-22-2019, 08:50 PM
NewbRVator NewbRVator is offline
FWIW I just spoke to a very experienced avionics pro today and he said he is mounting GPS antennas on the dash visor with good effect
20 dues paid member since 2018
RV6A
Old 04-23-2019, 08:13 AM
airguy's Avatar
airguy airguy is offline
Quite a few of us (myself included) have built a small shelf under the FWF engine cowling and installed them there. The fiberglass cowling is transparent to the GPS radio signals as long as you don't use paint with metallic pigments.
I've got two Garmin and one Dynon GPS antennas up there with excellent reception.
Old 04-23-2019, 08:55 AM
Carl Froehlich's Avatar
I ran with a GX-60 GPS antenna and a 396 GPS and XM weather antennas on the glare shield of the RV-8A for years with no issue. I mounted a SkyView GPS receiver and GTN-650 antenna on the glare shield in the RV-10 and it worked. I note the Garmin GPS antennas are more sensitive to mounting than the SkyView, so your mileage may vary depending on what you are installing. For the new RV-8 project the SkyView GPS receiver is going on the glare shield but the GTN-650 antenna is mounted on the fuselage just aft of the rear seat, but still under the canopy.
Carl
Old 04-23-2019, 10:22 AM
jpowell13 jpowell13 is offline
My xm and gps antennas are on glare shield. The antennas need to be black or the reflection is a problem. Also, gps antennas located too close to each other will interfere with one another. John
Old 04-23-2019, 10:50 AM
GalinHdz's Avatar
GalinHdz GalinHdz is offline
Similar to my setup except mine are under my glareshield with phonelic covered cutouts.
My G430W antenna has been there since 2009 while my Dynon antenna has been there since 2013. I have never had a problem with either of them while both of them show full satellite reception.
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
Old 04-23-2019, 12:08 PM
airguy's Avatar
Not universally true - I've got almost 400 hours like this with no interference.
Old 04-23-2019, 01:35 PM
Default Interference
In my case, it was my iLevil portable ADSB/GPS receiver that was interfering with the Garmin antenna for my 400W. It was interesting to watch the signal strength bars on the 400W drop as you moved the iLevil closer to the Garmin antenna. John
Old 04-23-2019, 07:40 PM
dave4754's Avatar
dave4754 dave4754 is offline
Default GPS puck location
I have my Dynon under the rear window and on a shelf mounted to the crossbar.
Many before me did this with no problems.
Dave Cobb
[color="Red"]=VAF=2019 Donation - and a bit extra for great work![/COLOR="blue"]
Empennage RV 7 - Tipper
Wings complete
Dynon installed and running
Fuse closer to completion, Canopy complete
AME reviewed and repaired O-320-Lyc installed
Old 04-23-2019, 11:13 PM
Black pucks on the glare shield...works beautifully. I use the "hook" velcro on the pucks which grabs the acrylic carpet on the glare shield like crazy.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
