04-10-2019, 01:56 PM
Registration RV12
I'm wrapping up the build project and have a question concerning the Aircraft Registration process. Do I need the packet of forms from Vans including the Bill of Sale and such or can I just download from the FAA, fill out and send to the FISDO?
RV12 - Flying August 2019
Restoring 1967 Ford pickup - no amount
of money will make this thing fly.
"I have enough money to last me for the rest of my life.
As long as I don't buy anything"
04-10-2019, 08:23 PM
I checked my AW package. It has three documents with a Vans signature: Bill of Sale, Statement of Conformance and the Affidavit of ownership.
04-10-2019, 08:25 PM
I guess that really didn?t answer your question. I reserved an N number without any of the paperwork I described, and as I recall I needed the bill of sale to complete the reservation.
04-10-2019, 09:16 PM
There are absolutely no "forms" required to reserve an "N" number. A reserved number is assigned to a person, not any aircraft.
You don't have to have an aircraft, a kit, or anything else. Just $10.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
04-10-2019, 09:38 PM
If you are going to register as E-LSA, or want to use the kit as a basis for meeting 51% as E-AB, you will need the Bill of Sale from Van?s; but that?s the only form you need from them. The rest of the forms are right here:
https://www.faa.gov/aircraft/gen_av/.../amateur_regs/
Ron Gawer
- RV10, Build in progress.
- RV12, N975G, "The Commuter"...many great hours and happy landings so far.
- Several others that are now just great memories for me.
04-11-2019, 07:26 AM
In order to register as E-LSA, Vans Aircraft needs to fill out and sign and give to you FAA
Form 8130-15 "Light-Sport Statement of Compliance". Vans will not provide that form
unless you buy every part from them and assemble the RV-12 exactly per the plans.
Joe Gores
RV-12 Flying
Reason: Corrected Typo
04-11-2019, 07:37 AM
Originally Posted by Mich48041
In order to register as E-LSA, Vans Aircraft needs fill out and sign and give to you FAA
Which is reason I have decided to go EAB. (experimental amateur build like RV-7 and 8 I built) We are getting paper work lined up right now. Have number reserved, waiting on Bill of Sale from Vans.
There is no advantage for me to go E-LSA, you end up with a quasi certified airplane, like a Cessna, very difficult to make any changes.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
04-11-2019, 08:17 AM
This is not correct.
An E-LSA is still an experimental aircraft.
True, to qualify for E-LSA you have to build it exactly per the KAI and present it that way for certification.
After certification you can modify it to any degree you choose.
The only limiting factor is that any modification can't make the airplane perform outside of the limitations of a light sport aircraft.
Scott McDaniels
Hubbard, Oregon
04-11-2019, 11:19 AM
Thanks for the help
I have an N number reserved and initiated the paperwork from Van?s.
Still have some work to finish up along with moving to the hangar, inspection and transition training. I enjoyed the build a lot more than the paper work
