Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Glass Cockpit
  #11
Old 04-08-2019, 09:29 AM
Brantel's Avatar
Brantel Brantel is offline
Originally Posted by Bavafa View Post
I get my weather from the XPNDR ADSB (45R), no Bluetooth for that setup and I have waited at least 15 minutes or so to see if I get the update.
Garmin has mentioned several times recently that the current firmware in the G3X Touch only supports these new FIS-B products over Blue Tooth. No hardwired connection support "yet".....
Check out the bottom of this post: http://www.vansairforce.com/communit...60&postcount=1
This is likely why you are not seeing the new products.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 04-08-2019, 09:31 AM
Brantel's Avatar
Originally Posted by sibriggs View Post
I find I have to go to the G3X setup screen on startup to reconnect the Bluetooth to the 39, it doesn't seem to want to reconnect by itself.
Steve
Not normal. I would give Garmin a call and get that sorted out.
Old 04-08-2019, 11:23 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Steve
Hello Steve,
Page 293 of the current Rev. L G3X Touch Pilot Guide explains how to enable Automatic Reconnect on the Bluetooth setup page for a device that you wish to automatically reconnect at each power up.
It is always better to contact us directly for product support.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 04-08-2019, 11:47 AM
Bavafa Bavafa is offline
You are correct, after talking to Garmin support, they indicated that the new/additional weather which became available thru SW update v8.2 is available only on Bluetooth for the time being and not RS232. They indicated that they are working on making it available on RS232 as well but it may take some time.
So for those who have their XPDR (45R) connected thru hardwire, you can go to Bluetooth setting, and pair with the XPDR. At least in my case that I have a GTN650, I had to accept such pairing on the GTN for the G3X to connect correctly.
This should fix the issue of waiting for data for cloud tops and lighting.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
