Old 04-07-2019, 04:49 AM
Hotscam Hotscam is offline
Default Maintenance manual
We just purchased the RV10 and trying to get organised.
We need a mandatory maintenance manual and sign-off ticklists to continue the AWC certificate. Nothing with the plane.
I can find these for the IO540 but not for the plane itself.
Anybody willing to share ?
Jack Netherlands
PH-SEP and PH-SES
RV12 #120519 and #120790
Hobbs 700+ hours and 400+ hours
Dual SV1000 Skyview 15, Pocket FMS and Powerflarm 6.0 (ADSB)
RV10 PH-USN Hobbs 350 hours
Old 04-07-2019, 05:25 AM
BrianDC's Avatar
BrianDC BrianDC is offline
First, congrats on your new RV-10.
For your question: There is no such thing as a maintenance manual for an experimental aircraft. Not sure what the regulations are for your area but assume there are different requirements for certified aircraft vs experimental.
Closest I think you can find is an example of what others have done for their condition inspection (equivalent to an annual inspection for the certified world). Looks like Tim Olsen has on on his website: https://www.myrv10.com/N104CD/mainte...225/index.html
As you go through the process for your new aircraft and find additional items you need to inspect, or things that don't apply to you, just change those items on the checklist! (At least that is what is expected here in the US).
Hopefully this helps
Brian Lester
RV10 - #41778
Empennage - Done (for now)
Wings - Done (for now)
Fuselage - Done (for now)
Finish Kit - in progress
RV10builder.com
KVKX / KHEF
Old 04-07-2019, 06:03 AM
Raiz Raiz is offline
Jack, great choice!
I don't know the regulations in the Netherlands but, in case it is useful, this is the guidance on creating your own maintenance schedule provided by the LAA in the UK:
http://www.lightaircraftassociation....intenance.html
They also published a couple of articles on the topic:
https://www.lightaircraftassociation...ticle%20FD.pdf
https://www.lightaircraftassociation...les/FD%202.pdf
Old 04-08-2019, 12:50 AM
Thanks. This will help me.
Jack Netherlands
PH-SEP and PH-SES
Old 04-08-2019, 06:24 PM
bob888 bob888 is offline
If you PM me your email, I will send you my inspection checklist.
