  #21
Old 04-04-2019, 05:27 AM
snopercod's Avatar
Just a couple of random comments from my experience:
1. Goo Gone works even better than Prep-Sol to remove adhesive residue.
2. 3M Primer 94 really makes adhesive-backed products adhere. You wipe it on, let it dry, then apply whatever it is you want to stick. Disclaimer: I've never tried it with wing walk.
(2020 dues paid)
Old 04-04-2019, 07:27 AM
MrNomad's Avatar
MrNomad MrNomad is offline
Thumbs up I have a plan - thx everyone
[/quote]
Great ideas! Removal of the old residue took hours last time. Also, the 3M primer got excellent reviews.
Typically, I fly at 135kts and < 2400 rpm to conserve fuel so the wife doesn't cut off my addiction. The "walks" stayed in place till Mon when I descended at > 150kt which excludes most boats.
Great website. Somehow I missed sending in my annual dues which I corrected yesterday. Thank u Doug & Blake for your follow thru.
Barry - Tucson
RV9A Superior O-360 (an amazing experience)
Dynon AP Garmin Sensenich F/P
2020 Dues paid. Thank u DR!
Old 04-04-2019, 09:48 AM
Flyin'Bryan's Avatar
Flyin'Bryan Flyin'Bryan is offline
Default Goo Gone
+1 for Goo Gone for adhesive removal. A few years ago while camping with my aluminum trailer at Airventure, a side window broke and I had no choice but to tape it up with trash bags and some very sticky Black Gorilla Tape. After getting home and removing the tape (1,000 miles), it left a rather sizeable amount of glue on the aluminum around the frame. I used the Goo Gone to remove it. It still took a bit of elbow grease and time to get it all removed, but it did so with no apparent damage to the paint. As always, better to test some of these solutions before going "all in" just to be sure, but that product seemed to work for me.
Ditto on the great thread - I would have never even thought about potential separation of the wing walk pad - or that this was something that ever actually happens - until I read this thread... just one more thing to keep in mind for later...
Bryan Raley
http://bryansrv8project.blogspot.com/
Building RV8
EAA Chapter 301
CFII/MEI, ATP
SportAir Workshop Graduate x 4: Sheet Metal, RV Building, Electrical, and Composite classes.
Tail Wheel Endorsement Completed
Empennage done, Wings in progress, N462AK reserved.
Old 04-24-2019, 03:16 PM
MrNomad's Avatar
Default wing walks came off in flight
I installed one of the replacement wing walks that flew off in flight.
Between Goo Gone, Prep-Sol & a credit card, all of the old adhesive was removed w/o damaging the paint. After removal, per Blake's instructions, the surface was repeatedly cleaned with 50/50 water alcohol.
"Snopercod's" suggestion to use 3M Primer 94 was absolutely brilliant. You wipe it on, let it dry, then install the wing walk. Make sure someone is helping you so the wing walk material goes exactly where it's intended the first time.
I tested the adhesive idea on another painted surface and the primer radically improved the adhesion. Better to spend $18 on a pint of primer than do this job again.
I waited a day and flew @ 160kts. The wing walk remained so now I will do the other wing.
Thx folks & thanks to Flyboy for their great customer service.
Barry - Tucson
Old 04-24-2019, 03:42 PM
flysrv10 flysrv10 is online now
Originally Posted by 219PB View Post
What about the ones from Vans? On my quotation from Glo Custom, they stated installing Vans wing walk material.
Have had Vans. 13 years and counting.
Old 04-24-2019, 04:04 PM
RV6_flyer's Avatar
The ones I got from Van's are still working well after 21-years and over 3,300 flying hours. They have been stepped on a lot.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 04-24-2019, 04:14 PM
Mine are attached and still look good after 18 years, but they don't offer the traction they once did.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 04-25-2019, 04:59 PM
RV7 To Go RV7 To Go is offline
I have had the Flyboys wing walks installed on my 7 for almost 2 years and 250 hrs. Used Iso to clean before installation. No issues so far...touch wood! Much nicer than the sandpaper stuff IMHO.
Al
___________
RV4 - Bought 2013 Sold 2017 after 450 hrs
RV7 - Built in 6.5 yrs & Flying 2017
Old 08-27-2019, 03:07 PM
BruceW BruceW is offline
I had my Flyboy wing walk fail (on a polished wing, may have something to do). Stumbled up a adhesive removal trick. Use quality masking tape (from plane painting stage). Apply, push onto remaining adhesive, and peal back. Takes a lot with it. Duh.
Bruce W
RV-7 QB
(500+ hours)
Elk Grove, CA
Old 08-28-2019, 08:14 AM
vfrazier's Avatar
vfrazier vfrazier is offline
Blake (Flyboy Accessories, and my son too) and I have puzzled over the occasional wing walk adhesive failure for years. Occasionally, it fails. We're not sure why since it's a marine product specifically intended for heat, sun, and water.
It's been on my 3 Waverunners for 10+ years with no issues, and was on my Rocket for the 9 years that I owned that plane, with no problems. I even used it on the floor inside that plane.
I plan to use it again on the new plane, an F4 Raider. And just put some on my RV-4.
As one post said, it sure is easier on your knees than the sandpaper-ish stuff.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
