The Borla unit I have has two outlet ports (it's a "T" configuration). I my case I have a bulkhead fitting as the fuel outlet through the firewall, and the other side has a reducer and the transmitter screws right into that.
Edit, I drilled and tapped the cap provided with the regulator... It's simply an AN plug.
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
