Old 09-25-2018, 04:01 AM
Discus2b Discus2b is offline
Well don?t that beat all....
H
Old 09-25-2018, 03:33 PM
springer springer is offline
Default More Switches?
I think I need more switches...
Jim
RV-4 '88-'09 Built & Sold
RV-8 Purchased
Old 09-25-2018, 06:32 PM
Quick! What is Vso/fe?
The 8 guys are way more humorous than the 14 guys. I screwed up.
ut oh ... 8 lurker
H
Old 10-09-2018, 11:03 AM
j-red j-red is offline
Finally got to put the driver to the screws this morning and officially install my panel. Had been waiting for the engine monitoring wire harness to be completed and now all the back-panel wiring is done and secured! (cable on the left side is a LAN cable that connects the VPX to a laptop for programming. It stays attached and stows underneath when not in use).
SDS iginition CPi swings down on the right if needed. Not completely invisible when in the 'UP' position, but certainly not an eyesore either. Once all the programming is done, I'll tie its wire bundle up more out of the way.
Rebuilt RV-6A N94CR
RV-8 N803DR completed, flying.
Old 10-10-2018, 07:48 PM
XPPilot XPPilot is offline
Default Panel finishing
Looks great! What material did you use for panel finishing?
Old 10-11-2018, 08:32 AM
It?s 3M 1080 series carbon fiber wrap. Pretty thick stuff with a realistic texture to it. I used the additional adhesive over the entire panel and really like how well it stuck and trimmed. It didn?t get twisted and turn by the screws which was a concern I had. It?s a little pricy, but the 3?,4? sheet I bought could probably do the whole thing all over again if it gets messed up at some point in the future.
Rebuilt RV-6A N94CR
Old 11-25-2018, 03:03 PM
Capt Capt is offline
I'm not a fan of glass (it's my day job) am old school, 40 years driving planes I still enjoy the good old days I would add a panel pix but can't get it to stick -
Old 04-03-2019, 08:49 AM
ksdflying ksdflying is offline
Hi all. I am trying to find one or two of you building or have built and RV-8, and with ALL Garmin suite of avionics. I need to install wiring in the aft fuselage and place some components there too. Looking for " What I should Do", or better yet, "I would Do It This Way IF Had To Again".
I want to minimize adding excessive weight but building all these shelfs and racks or what not.
Need to place the ELT, and I guess the 2-EarthX Batteries I decided to go with, and the Garmin Remote Transponder. Oh and the 4th and last item I guess is the GMU Magnometer.
Having a hard time finding photos or advice...all Garmin related at least.
Dan
Dan K. RV-8 kit purchased 2014, build start Jan 2018, Slow build Emp. done - March 2018, Slow build Wings done -Oct 2018, QB Fuselage started - Sep 2018
Avionics in - April 2019. Engine and Finish kit in hand 2019, installed. Slider canopy done.
VAF dues paid!
Old 04-03-2019, 08:59 AM
maus92 maus92 is offline
All G3X / Garmin panel. Mag mounted in left wing tip, remote transponder and radio and gdl39r mounted behind panel on a shelf. GPS20A and elt in tail. Since I retrofitted the plane, the wiring isn't as neat as Id like, and Id probably not do the VP-X only because Ive run out of circuits.
CA
2000 RV-8A | O-360, SDS CPI, FP, G3X Touch, VP-X, EarthX | Eastern Shore | KESN
Old 04-03-2019, 10:58 AM
BVD's Avatar
BVD BVD is offline
Default Panel Upgrade Phase 1...
Removed all the vacuum items, Navaid wing leveler, Rocky Mountain uEncoder, Garmin 250XL, GPSMAP 496, and a couple other items...
Installed a Garmin G5, 2 axis autopilot w/GMC 507 controller, Aera 660, and iPad running ForeFlight...
Phase 2 in planning stages...
Bill VonDane (BVD)
CO15 - Elbert, CO
RV-8A - Flying
CH750 STOL - Building
