Old 04-02-2019, 04:34 AM
pjmRV8 pjmRV8 is offline
Default RV-8 Prop Controller Issues
I have an RV-8 with O-360 A1A set up with a Hartzel CS prop. The prop controller teleflex goes through the firewall and makes an aggressive "90" to the prop governor on the rear of the engine.
After 1280 hours, it has become very stiff and hard to operate. I was wondering if anyone had any recommendations to revive the cable or good replacements. It is roughly 50" long and I believe is the standard green cable provided by Vans.
Any help would be appreciated.
Phil
Phil McCutchan
RV-8 N275RV
RV-6 N9HJ- lost to tornado
Evansville, IN
Old 04-02-2019, 07:15 AM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
Very interested in the replies. Mine has 400 hours and is almost there too. The throttle cable is harder to move than the prop for now.
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 04-02-2019, 07:30 AM
flynwest flynwest is offline
Default Green Cables
I have to replace my cables about every 300 or so hours. I cut one apart and found that the plastic liner used as a lubricant failed at the crimp. The liner wads up and causes the stiffness until it locks solid. I think it would be better if we could get cables that had to be lubed.
Horse Power is good, more is better and
Too Much is Just Right
RV 8 Super charged Barrett IO-390
Dues paid 2020
Dan "Nordo" West
Old 04-02-2019, 07:42 AM
Pilot135pd's Avatar
I thought it was binding at the bends so I disconnected everything firewall forward and let it hang straight out but it was still stiff to move.
As much as I like the good news that I only have to replace the cable and not re-engineer the design to find a better angle to install it, it still sucks that it has to be replaced so quickly.
Hopefully there are more out there that have gone through this and have found a solution to solve this issue more permanently than replacing every xxx amount of hours.
Are other models having the same problem with their cables and have they have found a different cable to replace it?
Old 04-02-2019, 08:03 AM
Ted RV8 Ted RV8 is offline
Have seen heat melt the plastic liner and cause binding. Primarily throttle cable as it runs under the exhaust system. Put a heat shield on the pipe when the cable was replaced. So far so good.
No lubing will fix it, cable has to be replaced.
On the governor cable for the prop did you put the cable and holes per Van?s drawing? Want the governor cable furthest away from the governor to ease the radius.
Old 04-02-2019, 08:07 AM
Pilot135pd's Avatar
Ok, looks like it's not just a RV-8 issue. Did a quick search "cable sticking" and found these informative threads :
http://www.vansairforce.com/communit...cable+sticking
Old 04-02-2019, 08:14 AM
Pilot135pd's Avatar
Should I install wrap-around exhaust tape on the exhaust pipe or should I put heat reflective tape around the cable? I was looking through the auto parts store online and found those two as heat shields, unless they have to be "aviation" heat shields?
Old 04-02-2019, 08:17 AM
Put a fire sleeve over the cable but didn?t cure the problem.
Purchased an exhaust shield from Van?s, so far working good.
Old 04-02-2019, 08:19 AM
Pilot135pd's Avatar
In one of those links I posted it explained why the fire sleeve will also fail. I'll look at the exhaust shield from Vans. Thanks.
Old 04-02-2019, 08:22 AM
Pilot135pd's Avatar
Is this what you bought? If so I'll need a couple of them :
https://shop.vansaircraft.com/cgi-bi...t=heat-shields
