Old 03-29-2019, 05:59 PM
bkc3921 bkc3921 is offline
Default Cleaning of Harnesses
I have read a previous thread on cleaning harnesses (I have Hooker)...but it danced around the issues: Is it permissible to use warm water and a mile soap and get the belts wet?...Or is this a step away from goodness?
Mine are not excessively dirty, but after years I would like to remove some minor surface grime. I was planning on soaking them in warm water and Woolite, followed by a very mild scrub, and air drying. Does this sound reasonable, or is it bad to even get them unnecessarily wet?
Any experts on this..?
Brian K. Morrow
DuBois,Il
N433BC RV-7A Flying
RV-12is EMP in progress!..Official Repeat Offender
"Maintain thy airspeed...Lest the earth arise and smite thee..."
Old 03-29-2019, 07:04 PM
Flying EMT's Avatar
Flying EMT Flying EMT is offline
Default Cleaning safety equip.
FWIW. The manufacturers recommended way is the route you should follow. To clean my firefighting safety gear there are a few rules: never use bleach or chlorine products, it weakens any Kevlar that might be woven into it. Check the PH of your cleaners, they should be as neutral as possible. Don?t use high temps water, temps over 100 degrees will degrade the fabrics. Air dry for same reason. I?m not an expert, but I use these rules to clean my harness and they seem to be holding up. YMMV. Ben
Ben Hubbard
180 hp RV-4
Enstrom F-28C
1979 Decathlon (In recovering mode)
KFOK Long Island, N.Y.
Old 03-29-2019, 11:14 PM
Malndi Malndi is offline
This recent safety notice addresses your question and supports Ben?s advice:
https://publicapps.caa.co.uk/docs/33...ice2019003.pdf
Old 03-29-2019, 11:22 PM
lr172 lr172 is offline
In the sailing world, we use woolite for cleaning nylon and poly lines. It is a very mild detergent and will do the least amount of harm to the material. Use cold water and not warm or hot.
Larry
Old 03-30-2019, 06:44 AM
rmarshall234 rmarshall234 is offline
That same type 7 and type 8 webbing is used for parachute harnesses and the approved method of cleaning is to use woolite and cool water. A mild scrub is fine, the two important steps are to make sure you _triple rinse_ to get all the woolite out and to make sure they air dry sufficiently. It's ok to hang in front of a fan for a few days if necessary.
