03-24-2019, 07:47 PM
Rotax warm up ops - your suggestions please
First off, I want to say that this question is posted only to gain answers - not in any way to disparage or be critical of anyone or anything - please understand - I seek info only.
Background - I'm in the early stages of my quest to obtain a Sport Pilot Certificate so that I may fly my RV-12 after completion and certification this year. I'm flying a Sling with a Rotax 912 ULS - pretty much the same engine that the RV-12 uses. Of course, there differences in the FWF install but it looks pretty much the same as the RV-12 install.
Situation - My Flight Instructor and I taxied out to the active runway at 2000 RPM, pulled into the warm-up area, and began the process of waiting for the engine to get up to the mandatory 122 degree temperature prior to take off.
The engine never got above 120 degrees F and then, only briefly as it hovered around the 118 mark. Wind was calm -OAT was about 68 degrees - altimeter was 30.12. Clouds overhead at 2000 - sky broken. Nice sunny day. We kept the RPM at 2000 degrees during the warm up attempt. After more than 1/2 hour, we decided to cancel my flying and I taxied back to the flight club. Please understand - we are not allowed to exceed 2000 RPM until the oil temp reaches at least 122 Degrees F. Water temp got up to 158.
Suggestions please - and thanks.
Building finally
03-24-2019, 08:38 PM
Verify the oil temperature via some other means. How about removing the dip
stick and inserting a thermometer or temperature probe in its place?
Joe Gores
RV-12 Flying
03-24-2019, 08:54 PM
At @ 68 degrees F outside temp my RV-12 Rotax 912 ULS engine warms up past 120 degrees OT very nicely. You are allowed to run the engine up to 2,500 rpms during the pre-120 degree OT warm-up period. At only 2,000 rpms it is no surprise that it might take a long time to get a rise in your OT. I suggest that you read the airframe and engine operating manuals applicable to your aircraft -- the information is all there.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
V AF donation through June 2021.
03-25-2019, 02:56 AM
warmup
I have found that on colder days if I run the engine for a few minutes and then shut it down and let it heat soak for a few minutes then restart i get to the minimum oil temp quicker than just sitting at 2000 to 2500 rpm
03-25-2019, 03:37 AM
We have resorted to a blanking plate on the oil cooler and the main radiator.
Much better ops, in flight temps are bang in the middle and you don't need a flask and sandwiches for the warm up
https://photos.smugmug.com/RV-Photos...IMG_3862-M.jpg
https://photos.smugmug.com/RV-Photos...IMG_3863-M.jpg
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Reason: snaps added
03-25-2019, 06:11 AM
What Dave says. Is there a reason you are attempting to warm up at only 2000 RPM? That is little more than an idle.
John Peck, CFII, A&P, EAA Tech Counselor, Flight Advisor.
?Master Pilot? Award, UFO Member.
RV-12 N37JP 120176 Flying since 2012.
One Week Wonder Build Team, OSH 2018.
VAF paid through 10/2019.
03-25-2019, 06:54 AM
I believe your best option is to pre-heat the engine before starting. This is best for the engine and significantly reduces warm-up run time. I have E-Z HEAT 912 engine pre-heater which I control with a cell phone relay switch.
See? http://www.vansairforce.com/communit...96&postcount=9
Jim Stricker
EAA #499867
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 618
03-25-2019, 10:07 AM
68F is a nice day. You should have warmed up fairly quickly. Absolutely no need for preheating. You should be able to warm up in 10 minutes or faster at 32F. I've always found warming up at 1,800 RPM is quicker then at higher RPM. I suspect that will shift based on the specific airframe. You have an instrument issue or some other abnormal problem. You shouldn't need to block the oil cooler off in that warm of weather. I would also take the time to download and read the operator's manual directly from Rotax. It's always good to cross-check anything you have been taught/read/heard. In an S-LSA, the POH overrides it, but it's how Rotax wants you to operate.
03-25-2019, 10:10 AM
You spent .5 Hr at Zamparini field on the Hobbs Meter, paying $65 to sit there idling and not flying, for your lesson?
OAT not being that cold, I am certain if you'd seen up to 2500 rpm, which you are allowed to do on a cold motor, you'd have seen 122F and the green light on the dash for the temp being OK.
I have seen this same symptom numerous times just 35 miles up the road from you in my friends RV-12 at Whiteman Airport.
Give the engine 2500 rpm in the warm up area until you clear 122F for your oil temperature, then proceed to check the A and B rpm drops at 4000.
I've seen the temp just get stuck at around 118F. 5 to 15 seconds at 2500 rpm seems to get the temp to get at 122F or above, so far, every time, here in Southern California, where we are at, where the temperatures are mild.
Read the Rotax operators manual, 2000 rpm, first 2 minutes, after that time frame, 2500 rpm is allowed, show that to your instructor.
03-25-2019, 10:11 AM
Thank you all
I'll read my engine manual and then show it to my CFI. He was acting as per flight club regulation so well see what the outcome is. Thanks again, ED.
Building finally
