For the cowl to firewall pins, I just make a 90 degree bend and fabricate a couple to "hooks" from scrap aluminimum that I attach inside the cowl and that the bent sections of pin can then click into. Its all hidden and works nicely. Also doesn't require any clever engineering.
For the cowl to cowl pins I have yet to see a system that completely satisfies me - I'm experimenting with different methods right now.
The simplest method I think is just to drill the tab, and adjacent cowl, put a nut-plate inside and screw the tab down. Its reasonably neat, and can be improved with a cover plate of some sort.
I recently saw an RV-7 where the pin end was bent back on itself and through another 90 degrees so it was perpendicular to the cowl surface, the bent end then located into a hole in the cowl. Spring pressure kept it in place. Neat and unobtrusive. I worry that it might lead to the pins popping out if not done very carefully.
I wondered about putting the pins in from the back ie through the cheek extensions - but couldn't see a good way to do it. Maybe you can figure it out?
After lots of fiddling I think I am going with the drilled tab. The only wrinkle will be that I will use a short length of tube, epoxied in place, as a lead-in to the hinge itself - that would avoid the otherwise inevitable little cutout in the cowls that to me looks a bit gash.
I've rejected the various pin lock systems on the grounds of weight. No doubt others will feel differently but I have been at great pains to minimise the weight of my -4.
Hope that helps?
Chris
I've yet
Chris Mitchell
Repeat offender;
RV-8, QB, built, flown 150 hours, sold;
RV-4 - attempted repair, rebuild and remediation - abandoned and junked   ;
RV-4 fuselage and wing kits - both at QB stage;
2015-2018 dues paid!
