B&C makes quality regulators so you will want to review the volts, amps and placement requirements match the Earth-X. When I discussed the batteries with Earth-X they have seen a couple issues with unprotected automotive charging systems in airplanes. They did confirm no issues with the Plane Power equipment I installed at the voltage and amp ratings. Give them a call if you have questions.
RV14-A QB
Factory Lycoming IO390 X, HZ CS 2 Blade,
Garmin Dual G3X 460, GTN 625, A/P 507, G5
GTR 200 & 20 COMM's, 245 audio, GTX 45R
Repairman Certificate
