Go Back   VAF Forums > Avionics / Interiors / Fiberglass > COMM
  #21
Old 01-18-2019, 03:00 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Originally Posted by g3xpert View Post
The GTR 200B uses the same rack/wiring as the popular GTR 200, and is a slide-in replacement for those wanting to upgrade.
Steve
Question about the new unit----------considering it is a "slide-in replacement" for folks who already have an installed GTR 200, are you offering the new one minus tray/connector etc???
If so, what is the $$$ saving?
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-18-2019, 04:11 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Mike,
No, that wouldn't make any sense. Whether you are going to sell the GTR 200 you pulled out, or install it as a second COM radio, you will need the rack and connectors which come with the new unit.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 01-18-2019, 04:18 PM
Mike S's Avatar
Senior Curmudgeon
Just thought I would check-----I already have the tray/connector, only need the radio.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 01-18-2019, 04:22 PM
g3xpert's Avatar
Post
Ok - that does make sense. I hadn't thought about that option!
You might check with the dealer you bought the rack from to see if they can help you out.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 02-27-2019, 01:57 PM
RWoodard's Avatar
RWoodard RWoodard is offline
I just bought a Citabria to keep my RV3 company and called Stein to order one of these for the Citabria.
Well, welcome to the world of Standard Certified Aircraft.
The comm only CERTIFIED version of this radio without all the fancy Bluetooth stuff is $1900! No sense in abandoning the existing SL40 if I can’t upgrade to Bluetooth.
Too bad Van’s doesn’t make something like a Citabria!
Rod Woodard
Brighton, Colorado (CO12)
RV-3 N87CT (Thanks Chuck!)
Glasair 1RG N388DM
RV-3 N99RV sold 01/2000
F1 MkIII empennage?arrived 08/22/2018--collecting dust
Old 02-27-2019, 02:48 PM
snopercod's Avatar
Steve-- On the GMA245, where would the audio from my AFS AoA connect. Aux input? And can the Aux input priority be selected so it isn't completely muted when a comm is being received?
(2020 dues paid)
Old 02-27-2019, 05:00 PM
g3xpert's Avatar
Post
Hello snopercod,
Not sure if you meant to post this on the GTR 200B thread.
Most of us connect AOA audio to one of the 4 unswitched/unmuted alert audio inputs on the GMA 245, but there are also 3 aux audio inputs if you prefer.
The volume of each of these 4 alert audio inputs is individually adjustable, so you should be able to set it the way you like it.
If you have additional questions, please contact us directly by phone or email shown below.
Steve
Garmin G3X Support
g3xpert@garmin.com
Old 03-05-2019, 05:46 AM
AzAero AzAero is offline
Fantastic radio! I just replaced the Apollo SL60 in my RV4 with the new GTR200b and couldn't be happier. Sound quality is excellent and find the features to be intuitive and easy to use. Purchased from Spruce with custom harness and installation was fairly straight forward with no issues. Not quite a drop in replacement, but very close. New tray is just a bit wider, and not as deep. Needed a little trimming and mounting adjustments.
Old 03-05-2019, 08:20 AM
sjhurlbut sjhurlbut is offline
Default Exchange
Garmin guys,
I have the GTR200 in my RV8. installed but never flown (expect first flight within next month).
Can I exchange mine for the upgrade?
Visit and subscribe to Stu's Aircraft Factory on
https://www.youtube.com/channel/UCGQ..._as=subscriber
Steve "Stu"
Cold Lake, Alberta
7A #70015 - C-FZQX - built - sold
7A #71629 - C-FSIS - built - sold across Atlantic
7 #70215 - C-GOJU - flying - sold
7 #70703 - C-GMIY - flying - sold
6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
8 #82842 - C-FSBG - Fastback - built - sold
4 #2723 - building
Old 06-13-2019, 11:55 AM
Draker's Avatar
Draker Draker is offline
g3xpert, any chance we'll see a Bluetooth-enabled version of the GTR 20 remote mounted radio/intercom?
Ryan Drake
Livermore, CA
https://stiletto.smugmug.com/RV7
Donated 12/16/2019
RV-7A (N12VD): Empennage and wing kits complete minus fiberglass, fuselage and wiring complete. Canopy complete minus fiberglass. Waiting for the engine to come!
