Go Back   VAF Forums > Avionics / Interiors / Fiberglass > ADS-B
Old 02-26-2019, 09:50 PM
JonGruber85 JonGruber85 is offline
Default Splitting adsb in signal. What method/splitter did you use?
Hi all. I have an avidyne MLB100 adsb in reciever that is wired directly from my adsb in antenna. I am now adding a dynon adsb in reciever to go to my skyview system. I am trying to split the coax to go to both boxes. So..... I have ordered this.
https://m.aircraftspruce.com/catalog...Lw_wcB#faq_tab
But the range says 5-500mhz so I don't belive it will work for 1090 and 978 Adsb. Anyone have other solutions? Straight splicing the wires or using a different kind of splitter? Any and all advice welcome. Thanks in advance!
Jon
Old 02-27-2019, 04:49 AM
noelf noelf is offline
Just FYI...Garmin installation manuals suggest using that specific part for splitting a VOR signal from one antenna to two VOR receivers.
Noel
RV-6A N6NF
tip-up
flying
Old 02-27-2019, 05:21 AM
GWZ GWZ is offline
Maybe not directly applicable to your $$ IN receivers but for my stratux I just have a ?T? connector I bought on Amazon that feeds both receivers with one antenna. I haven?t tried it yet but some of the stratux kits have it included so it must work (at least to some degree).
Gunther
2002 RV-9A 150hp
Old 02-27-2019, 05:38 AM
snopercod's Avatar
The ADS-B (in) antennas are only $60. Why not just buy another one? https://appareo.com/store/product/st...antenna-kit-5/
(2020 dues paid)
Old 02-27-2019, 05:40 AM
Purely for the reason of not wanting to put another whole in my skin. Or have yet another antenna poking out. But I see your point.
Old 02-27-2019, 05:41 AM
Interesting. I was trying to go the "correct" route by using aviation grade stuff. But if a 9$ Amazon part works...
Old 02-27-2019, 05:42 AM
Yeah I didn't read close enough at first glance. I assumed all coax signal/splitters were created equal. Thanks!
Old 02-27-2019, 06:29 AM
GWZ GWZ is offline
Well technically a combiner/splitter would be the way to go. A simple T connector is going to cause some signal loss. I have IN only (UAT) and have my antenna on the glare shield. I just added the 1090 receiver but I just don?t want another antenna up there if I can help it.
Gunther
2002 RV-9A 150hp
Old 02-27-2019, 09:03 AM
After a conversation with SteinAir...
He didn't know 100% but he guessed a simple 10$ T connection would work. But in the end I've made the decision to get rid of the avidyne unit and go with just the dynon adsb in
Old 02-27-2019, 09:40 AM
rocketbob's Avatar
Won't work. Even though you're dealing with receivers, without having isolation between the two, which cheap couplers don't provide, will cause the receivers to interfere with each other. A more expensive splitter will work but the signal is being split and there will be losses. Individual antennas will perform far better.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
