  #61
Old 02-26-2019, 12:09 PM
RV7A Flyer's Avatar
Originally Posted by rocketbob View Post
I doubt many people are out flying in RV's at -40F.
Not a materials scientist, but that seems to put it about the viscosity of ketchup, per Wikipedia .
Doesn't seem like that'd be much of an issue even IF one were flying around at -40F.
2019 Dues paid!
Old 02-26-2019, 12:14 PM
rocketbob's Avatar
lol perhaps filling a brake system up with ketchup is in order to do a proper test. We can't have experimental planes with any sort of defect on the fringes of reality flying around.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 02-26-2019, 12:19 PM
RV7A Flyer's Avatar
Well, while you're at it, might as well try to find the flashpoint of ketchup, too! Wouldn't want those ketchup-filled brake lines catching on fire
2019 Dues paid!
Old 02-26-2019, 12:23 PM
rocketbob's Avatar
Especially at -40F.
N8155F C150 flying
Old 02-26-2019, 08:32 PM
Charles in SC Charles in SC is offline
Originally Posted by rv7charlie View Post
Mobil ATF is synthetic. Just guessing, but it will almost certainly have a much higher flashpoint than traditional ATF, and will likely retain its other needed characteristics at a higher temp, too.
I don't know about that. The link posted shows Mobile ATF has a flashpoint of 356 f.
RV 7
Old 02-26-2019, 09:19 PM
https://www.noe.jxtg-group.co.jp/eng...4021-1704e.pdf
and traditional ATF:
https://www.acdelco.com.au/pdf/speci...s_dexronVI.pdf
vs Mobil 1 synthetic ATF:
https://mobiloil.com/en/automatic-tr.../synthetic-atf
Old 02-26-2019, 09:35 PM
hgerhardt's Avatar
Originally Posted by Robertc View Post
Best I can tell looking at Mobil?s ATF spec that it?s about 32 times higher viscosity at -40 deg than 5606A.
And yet cars in Alaska still have operational automatic transmissions in winter.
My flying-for-11 years -6 needed a 5606 flush when I noticed that the fluid in the plastic hoses had turned into jello when I added passenger master cylinders. Even with that 'goo' in the lines, the brakes still functioned just fine, and with no dragging when released. I now have flushing the brake system as a triennial maintenance item.
Old 02-27-2019, 03:49 AM
170 driver 170 driver is offline
Does anyone know if the ATF turns into sticky goo when it evaporates like 5606 does?
Jim Poe
RV9 First Flight 2/23/09
s/n 91416
